I have successfully moved the forum to the new server. I have also taken the liberty of updating the software to eliminate some of the more annoying bugs.
I have tested nearly all of the common functionality, and it seems to work. However, as we've moved locations, I've upgraded all moderators temporarily to administrators - any moderator or admin can help you reset your password if you get stuck.
I've tested this function and it works for me, but the e-mail took a good few minutes to get to me.
If that does not work, please contain *any* of the moderators or admins and they can help reset your password. If all else fails, please e-mail me directly at vanderaj@greebo.net.
If you have forgotten or want the Bad Attitude password, please contact me directly, tell me your username and state that you are over 18. Remember, it's not a forum for the thin skinned or the under 18's.
thanks,
Andrew
MickH ·
man this is heaps faster!!!
Stanley ·
some of the adverts aren't workinf for me
ColumBUS ·
this is a beauty good work!
VolksFolks ·
All good Andrew, didnt take as long as you thought hey!
If you want to post images bigger than allowed here, that's the place to do it 🙂
Andrew
*did* ·
u2u folders are not working for me
vanderaj ·
Okay, I'll check that out 🙂
Some statistics on our new server. It effortlessly coped with us. 🙂 Yay!
[ Edited on 29-9-2005 by vanderaj ]
vanderaj ·
By comparison, our old server regularly used to hover in the load 2-4 area, which means that the server has on average 4-8 processes ready to run, but can't. A load of 1.0 is fully busy.
Although the I/O's per second seem high, not all of them require disk access - most are serviced from RAM. We have plenty of RAM for us ... right now.
In an admin task we use, finding and deleting attachments with no associated posts, the server is 3.67 times faster than the old server. Gotta love that 🙂
thanks,
Andrew
vanderaj ·
U2U Folders now fixed.
oval TOFU ·
hey Andy, i think the DOWN link dont work... otherwise, it's just me...
[ Edited on 30-9-05 by oval TOFU ]
pete wood ·
ta Andrew, ya blood should be bottled. :kiss (for vampires...:P)
vanderaj ·
Oval - the down link does work for me - what browser are you using?
Andrew
oval TOFU ·
IE6
It used to work with the old server..
I'm not fussed - i've got a dwnpg button on my keyboard!
vanderaj ·
Hey, does it work any better now? IE 6 does not understand XHTML (which this software is progressively moving towards, which makes XHTML capable browsers like Firefox and Safari render faster and far more similarly) and the ID attribute for "bottom" was first, which IE can't understand. I also inserted a space in the a tag, so hopefully, IE and all its wonderous bugs might, just might work like any other decent browser.
If it doesn't work after this, I suggest upgrading to IE7 beta or Firefox.
Andrew
HotRodMatt ·
vanderaj wrote:If it doesn't work after this, I suggest upgrading to IE7 beta or Firefox.
I remember one of my mentors telling me the sign of a great administrator was to make systems work for the majority of users.
oval TOFU ·
nah, not workign still... I'll upgrade 😉
vanderaj ·
Hot Rod,
To a certain extent, I agree, but to comply with XHTML 1.0 Transitional (which is almost exactly like HTML 4.01), we need to make a few changes to the rendered output. As these changes are usually very minor, it is completely transparent for the most part. With these changes, all the decent compliant browsers (ie, anything BUT IE 6.0), they all see the same thing and it takes me far less time to code this application. Plus, because I force XHTML, they can use a much more modern renderer which has no "quirks" mode. This non-quirk renderer is typically a bit faster than the quirks mode browser.
IE 7 will fix the issues I have with IE 6 (appalling CSS support, mid-90's vintage HTML render engine, many more "quirks" than the others, offensively bad security - you cannot help BUT be infected by spyware if you go anywhere near a pr0n site). So I encourage all IE users to upgrade to it as soon as it is widely available. Until then, I strongly recommend for safety reasons alone to upgrade to almost ANY other browser.
Andrew
vanderaj ·
When IE 7 beta is released to the public (not long now!), you can grab it from here:
In the meantime, check out the Technical details. I'm pushing very hard in my bank to force low limits on IE < 7 customers when it comes out to encourage its adoption. IE 7 should rock your world and bring you close to Firefox 1.0's capabilities.
Andrew
Brad ·
should be quicker .. the new server is a damn side bigger, faster and all ours :>
Well done Andrew
gull ·
Andrew , I can not log in to the AVD as Seagull , the email adress for you above will not allow me to send an email to you it is returned
one problem I have found there is no way to contact any one regarding a problem here unless you are loged on .
apart from this you doing a great job .
cheers seagull , neil
vanderaj ·
Neil,
can you U2U me your e-mail address?
Andrew
Thanks for all the hard work Andrew....
vanderaj ·
Thanks Lee. 🙂
In other news - if you are wondering where many of the older posts are if you are looking through the forum lists (particularly Members Rides and General Chit Chat), we have not pruned any of the forums - the new code only shows the last 30 days by default.
If you want to see all posts in a forum, change the "days" setting (which is currently set to 30) to -1 and press "Go" to see them all. It will take up to 20 times longer - 4 - 8 seconds, which is why we changed the code to restrict it to just 30 days.
thanks,
Andrew
winerot ·
ah hah i noticed that in coming events it was less
very good so actually we have an archive section now
which means if idle after 30 days transfers to archive.
:thumb:thumb
wally
