Hi.
I need to take out the door panel on the passenger door, but I don't know how to take off the door handle or window winder.
Please help! 馃檪
pod 路
you need to knock out the pin in the back of the handle to get them off,you will see it if you push the trim in a little bit its behind the plastic spacer
bugeyedbabe 路
if ur talking about how u even get in...heres the trick...
on ur window winder...the winder has a plastic cover, slip it off and slide it to side...there will be a screw under neath so u can then take winder off...
next for the door....the black plastic section is clipped in....so get a flat head and clip middle section out....undo the screw then the rest of the black section will slip off..... u then slip the panel around the door handle (well i did neway...lol)
If u need to get the rest of the handle off...then follow pods directions...
VDubya 路
First reply is for early models, second for lates.
