Hi all
I have the oppertunity to get a set of Atlas white wall inserts for my late notch for $100.
So i loaded up Type Three Selecta and a had looky-see..
What do you lot think of it? looks good? Does anyone have pics of late type 3's with full whitewalls on stock rims, just out of curiousity?
And is $100 a good price?
Thanks,
Josie
YIOughta ·
looks good to me!!
Dont know about price but $25 a piece sounds good to me!😵💫
bitemeoz ·
i got them on my 69 and think they look much better than normal tyres. will say though they dont fit exactly right on all the tyres and fade as they get older. Also if one comes off or gets warped your up for a 2nd set to match the others. Which happened to me.
I got some omega ones for $90 a set.
jb
jo_tas ·
Ok.. well i think i might still try my luck... and TYP-114, the 60's look is what i'm after, it might be a late model, but i want it to look earlier..
karmannghia60 ·
I think the wide ones look great specially on dark paint. Here is a pic I got from the Net
Raf
pyr0 ·
i think they look sweet 👍
pete wood ·
go em, they'll look great I reckon.😎
waltermitty ·
Dont get them they destroy your tyres. My atlas ones did anyway the edge rubbed into the sidewall all the way to the cord in 3,000 klms, The whitewalls are harder than the tyres. Get the paint ed ones they look great and dont ruin good tyers. AANd DONT rub the gutter they disintergrate. ( alas and all flappers.
Mitchell
cab1303 ·
It would surely look hot!! My cousin has had them on his notch, and they looked mean!!:thumb
penguin ·
I think they look good, but I can understand WalterMitty's concerns. Any chance of just getting the painted on version? If so, maybe buy these inserts then see what it looks like. If its really sweet then consider the painting or next set of tyres as real white walls?
butidontunderstand ·
yeh i think im also interested in getting these inserts...would they look good on a red car?
bitemeoz ·
heres a pic i got from my garage
jo_tas ·
Why would they eat away at the tire?? they rotate with the tire, so how could it wear it out?
And if they wear out the tire that fast, how could they still be in business?
Are you sure they were fitted correctly?
The tires are already getting a bit old, so i like the idea of the inserts becuase i could put them on new tires as well, or sell them later and get painted ones on the new tires.
*sigh*
I just don't know what to do!
XXX-1.8T ·
dont listen to them do it!
Ive had my whitewalls for over 3 years and no probs 🙂
silver ·
I have just put them on my beetle they look great.
the manufacturers of the atlas ones recommend that tyre/rubber grease be used to avoid rubbing.
As the tyre touches the road it compresses in wall size, this is how the rubbing occurs, also the wider the tyre the more the rubbing
mine cost $135 so go for it
Silver
64vwmark ·
I reckon you should go for it!
twoguns ·
you either buy the flappers or get the strips etched and layed on using a latex solution... i had this done on my split.
65busser ·
They look great. Not period, but if you like it, you certainly wont offend anyone.
I've had sets on three cars now and the degree of rubbing seems to be dependant on the size of the tyres and the wheels you've got them on.. I've had one set that were no problem (165's on 5.5" rims), another that's a nightmare, (real hard 3" flappers) and... rears on the bug are ok but front 135's on 4.5" rims are eating away at the tyres. Mind you, I've only used tyres grease on the set that was OK. Silvers right, reading the instructions might help.
I reckon these wood look super fat. Real wide.Don't know anything about them, but love the look. 30's gangstar.
penguin ·
Jo
first of all, its your car not ours, so if you liek the idea go for it,
second, if the tyres are old, then what have you got to lose? you can see what its like for a minimal expense, have the inserts on a set of tyres that if (and I say if) they damage the sidewalls are you really going to be that upset as they are old tyres anyways,
Third, if you like the look and if they don't harm the tyres, sweet, but if they do hurt your tyres you can always plan to replace your old tyres with either whitewalls or have the new tyres painted prior to fitting 🙂
blutopless2 ·
i agree with penguin ^^^^^^^
if you like them put them on.. i will be putting a set of whitewalls on my oval. planning on using the thin type (i have been told there are two thicknesses) as i like the way they look.
Go for it.. its yours so do what YOU want. good luck
CAFFINEPUSHERMAN ·
i got them on my single cab but mine are the real ones old school is cool
wrecker67 ·
they look good,,hey bitemeoz good to see my old notch still looking good,,
the white walls are good,but i would go the painted way,not to sure about in tas,but here is a mobile called cool cruisin,do colours as well 0415904196 kevin...
cheers......:thumb
theverybigtallman ·
yeah i likem. i'd probly buy a new set of tyres and just paint them every now and then when they get too faded or whatever.
VDubya ·
Get a 3 inch brush and some ceiling paint.
Seen someone on here do it and all the kids think it looks the goods.
Purple Martin ·
butidontunderstand wrote:yeh i think im also interested in getting these inserts...would they look good on a red car?
yes, Yes, YES!
Especially if you also paint the rims red to match...
jo_tas ·
Hmm.. i'm almost re-convinced.. lol.. so it should be ok provided they are installed correctly with the tire/rubber grease?
pyr0 ·
yep. also dont forget to look into the white wall tyre painter 😉 but my choice is the white wall inserts installed properly 👍
62deluxe ·
I've got both on my cars. Love the look of both too. The wide inserts look totally different to the thin painted on whitewalls. I installed my own inserts, simply by deflating the tyre completely and then fitting them, no grease, no probs..
bus914 ·
go the fat ones, but paint the rims stock silver IMO.
bus914 ·
...and on a late (2000ish) beetle
kara&herkombi ·
yeah i put white walls on my beetle, cause they look cool.. i got mine installed at a tyre place and they stuffed them.. 3 out of the 4 have at least one section sticking out.. does anybody know if i can fix this problem??? i would go for the smaller thinner ones, cause mine are alittle too big and thick..
I think they will look rad on your car (so long as they are done right) so go for it!!!
volma1 ·
Here are a couple of pics of my cars with 1st painted white walls and 2nd real coker tyres with solid whitewalls
volma1 ·
sorry forgot pics.volma1
volma1 ·
next
volma1 ·
next, my 56 oval, volma1
Dannyboy ·
IMOA i think they are great. Can really change the way a car looks.
However they are a pain to fit properly and are high maintainance. To keep them looking nice requires careful driving and no mucky hands touching them.
A big plus is that if you dont like them or have any probs you can just take them off. If you have had a whitewall cut into your tyre and they look crap or have discoloured you got 4 tyres to think about changing or constantly getting touched up.
I went for yellow!
:P
squizy ·
So will any auto parts store sell tyre grease or a tyre place?
jo_tas ·
Wow.. this topic was dragged up from the grave!!
Sorry, i have no idea about your question... i'll just toddle off again...
boristherat ·
I love Boris's whitewall inserts (flappers). Don't know what the durability would be like on a daily driver but I have had em on my car for 6 months and they still look peachey!
I can't believe how $100 can transform a car.
CAFFINEPUSHERMAN ·
my flappers completly ripped off my daily driver bettle but i admit i drive like an absolute prick ,drive em like you stole em i say:thumb
