Late Type 3 door trim removal..
https://forums.aussieveedubbers.com/threads/44481/late-type-3-door-trim-removal
jo_tas ·
Hey
I am trying to remove my door trim so i can have a look why my window winder is sticking.. i've got the door handle bit off (the chrome thing), the window winder, the map box thingy, and now it still feels like theres something holding it in around the middle of the door.
My door trim is the type with the arm rest thingy running the whole length of the door, with a chrome strip running along that.
I've removed the chrome strip but there doesn't seem to be any screws under that.
Arrgh!
Please help!
bitemeoz ·
ok so i have a 69 but i think its the same, because it took me a while to figure out. You have to lift the whole door trim up. So unhook all the outside holders then grab it and yank it upwards. The trim pushes in and slides down to put it back in
john
squizy ·
Yeah - theres a hook at the back of the door handle. You need to now just lift the trim up, and it should come off the hook.
koolkarmakombi ·
check for screws under covers in the door arm rest
jo_tas ·
Thanks guys.. not long after i posted this i went and had another good look, and worked it out. Still, i'm sure this topic will be useful for others too!
Those tricky VW engineers!
72FASTY ·
dont forget to check that the glass isnt just sticking in the runners before you rip your door apart. Thats why mine was sticking when it got halfway down.
Midlife crisis ·
I found on my Fastie that the slider that winder arm moves along was very dry with no grease. I Cleaned it and put lots of grease and it worked much better.
Marc
jo_tas ·
Yeah.. i noticed there was alot of moving parts that felt dry.. i say "felt" because i couldn't really see anything.. lol.. but yeah, once i get around to it i'll grease everything in there..
Also, how do you stop the window sticking in the runners?
Midlife crisis ·
I use silicone spray it works really good ,you can get it from Supercheap- Autobarn ,etc
Marc
