Can anyone help. my 73 westy wanders all over the road .Its a bit hairy at times , where do i start.
lennyc..
pyr0 ·
in the wind or around corners ? or just driving in a straight line on a not so windy day ?
lennyc ·
he will wander off a straight line , a little in the wind , it just seems to have a mind of its own at times. Or more like driving down tram tracks, one minute your there the next you aint.
lennyc
MickH ·
Check out the steering box for excess play ,then the ball joints.
bus914 ·
if ^that's all good, get light truck tyres and Kyb gas shocks. make sure the front sway bar is still there and the mounts are good.
Kombi_Rescue ·
another tip is to check the drag link and center pin as these items wear.....wheel align check as tram tracking requires tow adjustment.....check front tyres for uneven wear this may indicate alignment issues...tyres reflect road conditions also...hard walled or big ply tyres will also cause the kombi wander....a softer thread patteren will give more stability and a little better handling...hope these tips help you solve the wander..cheers steve
lennyc ·
Thanks all. I will try the new tryes/shocks this weekend and see how it goes ..
Cheers Len.
