all were fine bar #2 cylinder inlet which was at .008 instead of .006 however i cant adjust the thing cause the adjuster screw is stuck in the lock nut and i cant turn it without turning the nut.
can i totally unscrew the thing and soak it in something to loosen it up?
Nick
DIY-DUB ·
wd40, to unstick all that is stuck
MickH ·
Be rough....unscrew the whole thing from the rocker gear and hold the screwdriver end with some vice grips and a spanner on the nut.If it breaks get a replacement as it was stuffed anyway...use ya muscles man😂😂😂😘
[ Edited on 13-10-2005 by Mick H ]
Anthiron ·
id rather not break it as i kinda need to drive the car. but thanks for the tip.
MickH ·
Anthiron wrote:id rather not break it as i kinda need to drive the car. but thanks for the tip.
What "being stuck" would indicate is that the threads are stretched in the nut.I highly doubt it will break as i have done it this way many times.It generally means you should relace the shaft and nut at the next service,they are cheap enough. Soak it in WD40 or similar first or give it some heat first. Then use your muscles.There won't be much stopping it from moving...:thumb
Anthiron ·
alrite ill get onto it mick. cheers
MickH ·
You have U2U
Anthiron ·
so do you
MickH ·
U do 2:beer
$2.63 homebrand baja ·
aww this such a cosy thread,,, I acn feel the lurrvee... :P
I am rekitting my first ever solex today.. it has weird things on it, ooohhhh and wires.. ahhhh,, and no choke lever......... and i can actually use the vw book for it... so exciting, not like stupid holden carbis 😠 not that this has anything whatsoever to do with tappets...just thought this was such a nice thread i wanted to join innnn by telling you I am covered in festy byproducts 😁
MickH ·
$2.63 homebrand baja wrote:aww this such a cosy thread,,, I acn feel the lurrvee... :P
Sounds like you got Festy excited (by products). Got some picks of him on the hoist at COR when i went down.Looked lonely and FESTY.
:bounce post them up! He IS excited, i have slowly been getting rid of the tiewire and strange bits and homemade trash. My theory is 'work from the ground up', you see as far as i am concerned all the 'go and stop' bits take priority over the stuff like body rust and windows etc. Bahhh, window winders etc, who needs em.. actually, once I have done the rounds with new tyres ($$$) I can start tidying up the body... He has decided enough is enough I am to stop neglecting him, he told me it's his time now, If he can go without the necessities for so long,, so can I 😉😂 actually i think he was getting pissed at being the butt of all manner of jokes and abuse, decided to become a reculse for a while till he got his shit together :P
MickH ·
Poor Festy...Will he work without the tie wire??
Anthiron ·
you have U2U 2 heather
MickH ·
I sent one as well Heather so you wouldn't feel left out.....
Sandy ·
awww 😍
ancientbugger ·
Nick,
If you need any parts like rockers etc. I have a dead 1600 at my place that you're welcome to if you're going past.
Bazza
