too low
https://forums.aussieveedubbers.com/threads/44782/too-low
kirk ·
hi guys.
just had a quote to raise my bug to the lowest legal limit.
quote.....
$700.00
does this sound right to you guys?
quote said the back end is easy it's the front thats the problem, needs this, needs that..
help wanted
56astro ·
What sort of vehicle is it?
Beetle, std or super
Golf,
Kombi??
twoguns ·
wouldnt it be a case of jsut winding your front back up? do you have adjsuters fitted? the back is easy.
kirk ·
its standard beetle, i don't know how it was lowerd first time round, and i don't know enough about it, i will get some more info.
twoguns ·
to be that low, it would need to have had some work on the beam. get unnder the front and take a look at the two large pipes running accros the front. in the middle there might be what looks like a bolt on a plate attached to each. this is an adjuster. you can then re set the height. if it hasnt got these, then i dont know... but i am sure there would be some one on here that will be able ot help.
the back is real easy. its jsut a matter of adjsut ing the torsion bar. i would wait a few days and talk to some one local form on here. they may be able to offer you some assistance. i know i would if you were up this way. good luck
shiftyvw ·
What excactly did they say it needed? Depends what repairs theyve quoted.
kirk ·
o.k just got more info...
when it was lowered they have taken the torsion leaves out? what ever they are..
is this bad?
do i have to bin this project or would it be better to get a new front beam?
cost for raise is $700.00.
how much for a new front beam?
Adam_C ·
Where are you!!! someone might be avle to offer more assistance.
For instance they can locate you a replacement beam and possibly help you fit it.
BUGBOY ·
$700 sounds like a rip off to me.
You just need a set of leaves fitted.
kirk ·
im in melbourne any assistance and info would be great from any of you guys, im a bit green on this subject.
