I am looking for the windscreen frame body section from a 60's ghia cabrio. The one on the car i have, has been damaged and poorly repaired at some stage in the past.Any help appreciated .Please call Tony 0412370071
karmen ·
any pics
u dont mean the chrome rubber insert ?
Tonz Magonz ·
No , I am wanting the steel body section which holds the windscreen and roof section in place . Tonz
Karmann ghia seller ·
i think you might find chicken teeth easyer to get hold off
as to cut the frame of a vert would be sacralige
to find a vert rough enough to cut up i doubt it
find a good panel guy to repair
or buy my 69 lol
lots of luck
[ Edited on 16-10-2005 by Karmann ghia seller ]
Yogie ·
Check Samba as I think there is one on there at the moment. From memory it looked like it had been cut off about 2/3 of the way down from the top corners.
Yogie
karmannghia60 ·
Looks like a coupe is getting turned into a cabrio. Good luck
Raf
SPRINTSTAR ·
Nope, it's the real deal, factory RHD too!
Tonz Magonz ·
Thanks Yogi, I will try and find that ad. on samba.Its the real deal but has suffered some damage around the base of the windscreen posts at some time in the past and poorly repaired, but can be rectified if replacement sections are too hard to source.Its only metal!! Tonz
Yogie ·
I just had a quick look on samba and couldn't find the one I had seen but there is this 70 model rolling shell for US$300. He may cut out the frame for you if you pay him to do it.
hi
dont forget the vert frames differ from 60-691/2
they have hook type locks
691/2 they changed over to pin type lock on top of window frame
so the 70s one no good to him and the early ones are so hard to get anywhere
good luck
[ Edited on 18-10-2005 by Karmann ghia seller ]
Tonz Magonz ·
Thanks KG Seller, I was wondering if there was any difference.Looking more like repairing what i have. Are there any detailed drawings of the ghia bodies showing dimensions of body parts.; ie( door opening m'ments or angle of windscreen frame . etc )I want to make sure everything is where it should be before adjusting door glass and hood for example..???? Any help out there ?? Cheers Tonz
[ Edited on 19/10/2005 by tanstee ]
hi
if you go to
karmannghia.com
see there catalogues it has full brake down of ghia
body that will set you straight and order are catalogue for your self $15au in the mail cheap
good luck
SPRINTSTAR ·
If you wish Tony, I work at Albert Park, you can swing past the office and pick-up my Karmann Ghia Parts & Restoration 2005 catalogue and have it copied at Officeworks. It is excellent for reference and parts listings.
AL
p.s. No such thing as rare, just gotta pay to play....
[ Edited on 19-10-2005 by SPRINTSTAR ]
Tonz Magonz ·
Thanks AL, When am i gonna get a look at your new project ? Tonz
hypo-vw ·
if you call Arie on 02-42711179 ( bus hours ) he may be able to help you . He imported 2 ghia cabriolets from US some years ago , and I recall that the morons that were shipping them in US cut the windscreen sections off both cars to fit 2 of them in 1 shipping container . Arie was so pissed off !! He is the type of bloke that hoards everything ,so I am certain that they will still be there . 1 of the ghias that arrived was so rusty that he was never going to restore it . GOOD LUCK !!
karmannghia60 ·
Try Max from Dandy Volks in Dandenong. He has been repairing Ghias for years. He might have one.
Raf
Tonz Magonz ·
Thanks Hypo and KG 60, I will look into both your tips. Fingers crossed!! Tonz😵
byronbus ·
Tonz, you have a u2u
Yogie ·
If you are still looking, I found the original ad on samba I saw. It is for a 60s cabriolet but is cut off a few centimetres from above the base of the dash area.
Thanks Yogie, I checked out the samba ad but ideally need more of the base of the screen surround to justify cutting up the ol' boy. If i can get some good goggles i might take the whole screen off!! No more trouble from window washers at the traffic lights!! Cheers Tonz😂
