vwma-craig- towbar pics
https://forums.aussieveedubbers.com/threads/44906/vwma-craig-towbar-pics
winerot ·
hi craig
heres some pics of the tow bar,i can understand that
some would rip out as all hire trailers are 800kg alone
plus you throw a car-van on thats a lot for a kombi.
i found it to be a worse time when your going empty
& hit a bump, pot hole or what ever & the empty trailer
jumps & jerks but with some weight on its a much smoother ride.
its not rust in the pics its tamworth mud was pissing down
cheers wally
as my sig says its fun taking the van to extreme
now its lowered i can not do much 4wd now:P
[ Edited on 17-10-2005 by winerot ]
VWMA Editor ·
Thankyou,
That's pretty much the setup I'll be running. Do you have 3 mounting bolts on both sides? Or is there only room for 2 on the right?
I notice your 'cosy' fit with the pipes. After fitting extractors I had to have Dave from Custom Off Road slightly modify the tongue and mounting points on mine just so it would fit. Still tight though.
Thanks again.
winerot ·
the right side only has two because i lost one but there is three holes for it
& it was a tight fit with the extractors but it does fit just.
cheers wally
