am after some wheel cylinder seal kits for 56 beetle anyone have any they want to part with also after an adjustable front beam to suit 56 beetle but want a bare one
rob
its just as easy & inexpensive to buy NEW brake cylinders..
check out ebay plus aftermarket vw parts sellers who advertise on here...
If you still have the origional 2 bolt wheel cyclinders then give Vinatge a call, or if you have the latter ones they also have the kits available 9789-1777
they can do your beam as well.
glider69 ·
dave rang vvds dont sell kits only new cylinders 2 in stock only
rob
kombikim ·
I got those rear wheel cylinder kits off Classic Vee Dub at Rydalmere, they were about $45 each which was laughable,
& the 57 on were half the price of that
glider69 ·
rang burt bros in fairfield $6 each corner pretty cheap considering i was quoted $122.00 + gst each for new cylinders my cylinders are new seals gone hard from no use
rob
do you have 2 or single bolt cyclinders ???
glider69 ·
have a look 2nite but last time i felt em i still had 2 nuts
rob
Midlife crisis ·
classic VW has new ones form 19.99
Marc
kombikim ·
yep, it is in their monthly specials
but that is for the 1957 on models, the early ones are still really cheap though can't beleive I was gonna stuff round & get the old ones resleeved the actual rubber cups are available at most brake places from stock though, I got a couple up the rd before I found the cylinder was clagged
[ Edited on 19-10-2005 by kombikim ]
glider69 ·
no wucken forries get it sorted out tomorrow
thanx guys
rob
kombikim ·
I was busy at work before, did not have time to say for general info, it is not good to ask for a wheel cylinder kit for an old car at brake places, these generally include the piston rubbers (or cups) which are the critical bits & the outer rubber seal which you rarely need another one of , & occasionally a spring or spacer which also arent necessary HOWEVER if you just ask for the rubber cups most brake places have em on the shelf for what is a nominal amount of money, or can get them in one day at most
I am sure you know this Rob, but a lot of people don't
