What Mask to use when sanding BOG and PAINT??
https://forums.aussieveedubbers.com/threads/44963/what-mask-to-use-when-sanding-bog-and-paint
ruckus ·
What type of mask should be used when sanding away bog and paint w/elec sander/angle grinder? Cheers!
**This is REN using RUCKUS computer.....
If you are using disposable masks, get P2 style with the valve for easier breathing. They will cost you about $3 each in a box of 10.
Otherwise get a rubber mask with a replacable cartridge capability. You can then get organic filters which filter out thinner and paint fumes also. They are not suitable for two pac. They usually go fo $20-$25 with the cartriges being about $8 each to replace. They are available with one or two cartrige holes, and that just means they go for twice as long, but you need to buy two cartriges.
ren ·
Thanks for the info Helbus.....
