Where can i buy some white vinyl to use for car decals??
https://forums.aussieveedubbers.com/threads/45126/where-can-i-buy-some-white-vinyl-to-use-for-car-decals
Dannyboy ·
Before i go ahead and start respraying i want to see how something looks and figure that using white vinyl would be the way to go. I realise that there will be edges etc but at this stage i'm more interested in the whole look and if it's worth doing.
So my question is where can i buy suitable white vinyl from in Sydney , preferably in large lengths and width's ?????
Cheers Dan:thumb
lohoon ·
yeah i just tryed a similar thing.First i went to the local$2 shop and bought some cheap contacty type book covering.Kinda worked but ripped easily and could only be applied once.(no repositioning)
So then i went to local sign shop and bought some strechy,thicker type vinyl stuff.
hope this helps.
scott
[ Edited on 23-10-2005 by lohoon ]
Gibbo ·
Try the local sign-writing shop, they may even give you some off-cuts for nothing....
1500S ·
If you want to reposition sticky vinyl, use a spray bottle with water and a little detergent in it to spray the area. Makes it easy to lift and shift to different spot before final positioning.
barls ·
try contacting warb cause he works that kind of stuff at his job danny
Dannyboy ·
Cool i'll try a few sign shops then! Cheers
Dan:thumb
Adam_C ·
You can also get "application tape" in about 1m wide rolls.... cheaper than the vinyl. check it out .... its like masking tape but 1m wide
speedster356 ·
Danny I've got a roll of white but only 300mm wide, if it's any use I'll drop some over.
warb ·
yeah, let me know what your after, i have access to all sorts of offcuts/stuff ... application tape comes in 1220mm logs also.. same with vinyl.. im sure i can get you some for free...
karmannghia60 ·
Spot light. About $7/m
