quick shift kit
https://forums.aussieveedubbers.com/threads/45205/quick-shift-kit
bond ·
hi all, have just installed a quick shift kit onto my bug - only problem is now i cant find gears - specifically first - when i sit it so i can go into first all is well untill coming back from third to second where it wont go into second and will grind - any tips on how to sort this out is greatly appreciated
thanks
nick
barls ·
it sounds like its only just out of alignment. can you get the gears when the engine is not running
bond ·
yeah i can - its only when driving do the gears grind? i can call you barls if that sweet? thanks mate
nick
barls ·
u2u sent mate
bond ·
sorry man, didnt get any u2u as yet? might not have put a title in it?
barls ·
try again mate not that ill be much help
did you put the tab on the plate the right way up??
Which way was it Barls (hey - welcome back! - beer soon??)???
barls ·
i believe it was up and on the right does that sound to you barry. i spoke to bond a little while ago and i think its just out of alignment but it could also be the plate didnt think about that.
yeah barry will have to catch up for a beer soon maybe the friday night before the shootout maybe. not this week as ive still got to finish the anti malaria medication.
right and up
beerdoc ·
The ever reliable Bizare with the diagrams
Mate you are a legend:beer
bond ·
ahhhh far out - i just fiddled a bit more - its a 73 standard - i had 2 tabs though - 1 longer than the other???
i cant remember where which side it was on either - ive been changing it back and forth so im not sure now...
have put it back to stock cos im running out of time and need it to be driveable for uni tomorrow bu twill try again on the weekend
greatly appreciate the help barls and bizarre!!!
nick
It is the big tab to the right and up
If you can get it to work without the kit then either you are not setting it up right or out of alignment (:duh)
What i mean is
a) the plate is moving when you bolt it up. When it is in standard mode and working, get a scribe and outline the plate. When up put the kit in look down and line it up with that. Amazing how "out" you can be when you are 20mm higher
or
b) the plate is wrong way or something. You did take the knob off and slide the mushroom on???
bond ·
i think it was just the alignment - you're right though, my eyes ain't so good with another 20mm in the picture. the mushroom is on the right way and when i try again this weekend will outline the plate first 🙂..... is funny that when you buy these things all you're told is that its a 10minute job and it bolts straight on haha...
thanks again
nick
the 2nd time it is! 🤪
76camper ·
Hey, was having the same problem with my shifter. The crunching is you hitting reverse. I just changed it till i got the thing right. As for adjustment, http://www.acvw.com/article.asp?DetailID=38
i think i had mine as far right and forward as it would go. The crunching is just the little guide plate not the right way round. Just have a look at that diagram ^^^^ and copy it. good luck with it
