Wheel hubs 4 stud to wide 5 question
https://forums.aussieveedubbers.com/threads/45275/wheel-hubs-4-stud-to-wide-5-question
Stealth ·
Can anyone tell me what (if any) year rear wide 5 wheel hub will fit on a 74 beetle box with 4 stud hubs to fit wide 5 wheels??
Stealth
seagull ·
The spline is the same , I ( think ) the backing plate will bolt up the same .
guys ?
Why dont you just buy good quality adaptor plates. Vintage 02-9789-1777
The early rear brakes n hubs are narrower so you will have to fit the backing plate and brakes as well. You will also need a spacer to make up the different in the length of the spline
Desert Bug ·
G'day Stealth,
Best option would be late (
jnr356 ·
early type 3,may need a spacer between the drum and nut
Stealth ·
Thanks Mark, i will probably go that option.
pete wood ·
vw54 wrote:Why dont you just buy good quality adaptor plates. Vintage 02-9789-1777
adaptors are illegal aren't they
