Leaking Brake Fluid!!!
https://forums.aussieveedubbers.com/threads/45306/leaking-brake-fluid
XXX-1.8T ·
ahhh this shits me ive change the brakes, liners, and master cylinder, and master cylinder plg but after about 30 days i have no fluid and no brakes
very dangerous!
Anyone know where else i should check?
Is there anywhere i can go to get upgraded lines cos they are still oem and im guess the rubber on the ends have maybe worn out?
My cars a 66 with 4 wheel drums
HELP!!!!
silver ·
You'd think there would be wet spot somewhere around the wheels or even under the carpet, check the line seving the rears, keep looking Costa it has to be going somewhere
Any brake place can re make your lines and Muller has new wheel cylinders (German ones) if they are stuffed
Silver
jnr356 ·
take out your drivers carpet(or mat )and check the steel brake line that runs from front to rear
they get pinholes near the s bend past the pedals
Adam_C ·
Costa. pull up your rubber mats. look for moisture. jack her up and look at the front and rear lines, the rubber ones. there us 4..... 2 front 2 rear (obviously) feel them for moisture, bend em and look for cracks. check the hard lines and where they go into the drum backings.
if that all fails........ get your mech to pull the drums off and check the wheel cylinders.
Kombi_Rescue ·
hey costa some one is stealing your fluid ?
XXX-1.8T ·
I found the leaks its coming from the front behind the spare tyre my guess its the bottle it self
im soo happy!
