Wiper blades?
https://forums.aussieveedubbers.com/threads/45426/wiper-blades
benno_h 路
Hi guys,
I have a '58 T1 with those *tiny* little wiper blades, anyone happen to know where I might be able to find some on the Gold Coast?
Would prefer not to mail-order cause I'm trying to get the girl ready for a RWC ASAP.
Benno
ratty 63 路
...correct me if I'm wrong, but a '58 uses the same wiper blades as a '63 doesn't it?
Try any of the VW mechanics on the Gold Coast, they usually keep them - if that fails try ordering them through any of the general parts suppliers (Repco, Autobarn, Global, etc) - they are still made, but not usually on the shelf.
Hope this helps
R 馃檪
ian.mezz 路
yes i got some from repco about $8, think trico band
VWFREAK 路
Give Vintage Vee Dub a call in sydney, I bought some about a week ago, $22 ea.
nbturbo 路
Some of the Trico blades have a small cutout about 15mm from one end-if so you can push the rubber back and pull it out thru the slot-then just buy any replacement blades with the plastic back-cut off one end and pull the rubber out and cut to length and feed it back into your original.You can usually get enough out of one blade to do 2 VW blades.
benno_h 路
Cheers guys
Ratty, could you reccomend a VW shop on the 'coast? I've just moved down here and don't know my way around yet ;-)
benno
ratty 63 路
Hey Benno,
I have sent you a U2U with the details of the VW parts suppliers on the Gold Coast (I don't know what the go is regarding the mentioning of Business names in posts - so best that I don't).
Nbturbo, can you still buy the replaceable wiper blade heads new? I have a set of old ones that I found at a swap meet on my '63 now - much cheaper and easier to replace the blades using them!
R 馃檪
benno_h 路
ta :-)
ColumBUS 路
to replace my wiper blades i bought some cheaper wipers from go lo and cut to size, cost $2.50 and iave never had a problem
nbturbo 路
Ratty-I tried at Autopro to get some-they have a listing and pics-but each time they turned up,they were about 2 foot long and 6mm wide-from something industrial I think.So I have been getting them from wrecks and storing.they are stainless and polish up nicely.For the moment I am using a small stainless split pin to hold them on-but am trying to find some aluminium rivets long enough to use.
[ Edited on 4-11-2005 by nbturbo ]
