SERIOUSLY. THIS IS LIKE ASKING IF A SQUARE OF 40MM FITS IN A CIRCLE OF 40MM OUTSIDE DIAMETER. WHAT ARE YOU TRYING TO ACHIEVE ????
Desert Bug ·
NO!!!
waltermitty ·
Oh is it , WELL YOU DONT NEED TO SHOUT> you rude P***K
mm trying to achieve?? perhaps finding out something that I didnt know about,,,, DER!!
This is the tech forum thanks for your help.
Mitchell
VDubya quote-
"I was going to join the Democrats to keep the bastards honest, but I became a dick head instead!."
waltermitty ·
Thanks DB I doubted it however with VW you never know what bits are common.Mitchell
Mitch
From memory the Bug shocks are shorter, so they wouldnt have the travel distance on the Kombi. and vise versa i suspose
Menangler ·
Splitty Kombi shocks will change with king and link beetle shocks, they are the same,
The later bay rears are way too long for a Beetle.
Desert Bug ·
G'day Mitchell,
Bay shocks are longer (rear by quite a bit), Splitty shocks are same length as early Beetle but much fatter, bj frontend Beetles have pin type tops on the front shocks and later ones had a long bolt tube at the bottom eye on the rear shocks.
Hope this compensates a little for the strong "no".
Cheers, Ian.
waltermitty ·
Hi Ian , of course I wasnt talking about you but the post above. Thanks for the intrest. Mitchell
karmen ·
on ya mitchell
it is valid with so much interchangeable on vw
have a lot of pr 68 beetle shocks if u want ...good too
chaep
pugvan ·
bug rear shocks will fit bay front if bay has been lowered
