Aussieveedubbers 路 Tech Talk
How much tension do I need for a clutch pressure plate?
https://forums.aussieveedubbers.com/threads/45613/how-much-tension-do-i-need-for-a-clutch-pressure-plate
foxy_fuchsia 路
To tension a clutch pressure plate is it 18ft/lb??
Thanks 馃檪
barls 路
the easiest way is to use a torque wench to do it as it will give an accurate reading any other way is guessimation
foxy_fuchsia 路
Yep using a torque wrench or whatever that thing is that you set the pounds setting to and then tension it. Was just wondering if we have to set it to 18 pounds?
barls 路
yes thats right id do it all to 10 pound first then check that the clutch alignment tool moves freely and if it does then to 18 making sure that you do the bolts in a diagonal pattern ie opposites
foxy_fuchsia 路
Thanx Barlsy, your a legend! 馃槏
barls 路
not a problem i hope it made sense as im in to my own :beer at the moment
foxy_fuchsia 路
perfect sense :rudolf
68AutoBug 路
AS BARLS said...
You do up clutches and other things, even wheel nuts/studs ... a bit at a time... and You do the opposite ones all the time... or closest You can get....
NEVER just go round doing the bolts up in SEQUENCE.....
