modulus wrote:Dasdubber wrote:Yeah Mike there are some restrictions in QLD - I know Wes posted a link to the draft vehicle modification rules somewhere in here - it may be changing but not sure.
I narrowed my front beam 80mm, however this was to regain turning circle when using my 17x7.5in ET52 wheels. To get the wheels away from the trailing arms, I then used spacers (bolted to the discs with studs for the wheels) - thereby regaining the track width (ie. narrow beam but space wheels out). Spacers/adaptors in themselves have to be approved, and because I worked with the engineer throughout the design of the suspension and braking system I had no problems having them passed - however you can't just bolt a pair of spacers on without the proper authorisation. I know some late model porsches come with them equipped from the factory which is of course an exception.
Back to the narrowed beam though - yep that is a good link (I've had that in the favourites for ages too!).
Hi Das,
I confess I've read this about four times over the past months, including in your excellent build report on the car and ended up puzzled each time. Apart from some pretty subtle geometry changes (there's now a longer arm pivoting from a closer inboard pivot point) , didn't you end up offsetting one action with another i.e. could you not have reduced the amount you narrowed your beam by the thickness of your spacers (X 2) then not fit the spacers, and still have had the centreline of your wheels in the same place, i.e. the same track? So assuming your spacers are 20 mm thick, could you have narrowed the beam 40 mm, not 80 mm, and not fitted the spacers?
Apologies for the convoluted question; I'm sure I'm missing something obvious.
The most common 'problem' that is found when fitting late Porsche rims is the offset. Some of the rims have as much as a 52ET... Which is huge for a rear wheel drive car! (most front wheel drivecars have around 42-47ET) Good for getting the rims under the guard, but not so great if you have big brakes too. What this means is the inside edge of the rim and tyre gets very close to the related suspension components, and the brake components get very close the wheel centre. Now when you add big calipers from the Porsche range such as the big reds, you would have major clearance issues if you did not run spacers as well. Porsces run a fairly large offset spacing from the rotor to the hub face. So you have to take into account the backspace (ET) of the rims, the hub face, the disc rotor and the various components hangin off the car under the guard. This is when the need arrises to select the correct spacer to get the rim as far under the car as poss and still clear all the bits that are bolted to it! Of course you must take into account the outer guard clearance issue as well. Obviously it is best to make as much room as poss under the car (narrowed beam), then build out from there.... If you wanted to run aero guards et al, then a narrowed beam is more than likely not nessasary, but some of us like the look of the stock guard (I know aero's dont do it for me!).
On my ragtop, I currently have the aformentioned 2" narrowed beam... I did this primarily for cosmetic purposes, but I also did this because I am running RADAR rims. Now anybody who has these rims will know that the offset is less than ideal (its a very old school 20ET). To get these rims under the stock guard on a very low car with anything bigger than 185 would be tough... I have 145/55-15's on the front and they look pretty close to stock in track on my car... Add to that some drop spindles and I think you may have guard lip clearance issues... Hence the need for the 4" narrowed beam.
Now I know that some ppl will tell you that the car will have suspect handling, and of course the handling will be effected when you narrow track, but I know from experience it is not as extreme as some would tell you.
If you are running a mildly narrowed beam(2"), with big brakes and rims, then I would doubt you feel a difference and you will appreciate the tyre to guard clearance. If like me, you are runnning narrowish tyres on the front (for that hardcore gasser look!), I would advise some care when negotiating that favorite roundabout of yours. But you would if your beam was stock anyhoo! Extreme beams such as the 6" - 8" deals that are so popular in the US are pretty suss, but these guys dont have the same crap roads we have, they drive mostly on the smooth interstates or cruise the boulevards, and the licensing laws are fairly flexible compared to our guidlelines. Im currently going through the engineering permits for my 4" beam... I know of plenty of hot rods that are legally running altered track widths, lets hope the engineer like what he see's...
