Beetle master cylinder bore size?
https://forums.aussieveedubbers.com/threads/45917/beetle-master-cylinder-bore-size
Secoh ·
What is the bore size for the single circuit ('68) beetle master cylinder?
Did the L bugs have a twin circuit master cylinder?
Anything that bolts straight in more or less?
dangerous ·
17mm I think.
Later (when?) went to 19mm.
L bug has an angled bolt pattern.
Will fit with some work...don't forget the spacers in the bulkhead!
[ Edited on 13-11-2005 by dangerous ]
The single curcuit only came on the drum brake model 67 or earlier, it was 19 or 17mm. The dual curcuit ones were all 19 mm.
Secoh ·
hmmm looks like they kept the drum master cylinder when they turned it into a buggy then...
thanks guys will grab a new dual circuit one then.
