Need to borrow some wheels.... pretty please?
https://forums.aussieveedubbers.com/threads/45958/need-to-borrow-some-wheels-pretty-please
PrettyBlueBug ·
I'm wanting to get my Teledials sandblasted so I can polish them. :P
Would there be some kind being out there with a good set of Porsche stud pattern wheels that they'd be willing to let me borrow for a fortnight or so while this is being done? Or even if you just have 2 wheels and would let me borrow them for a bit longer to do a pair of mine at a time.
Ideally in the Melb area so I could pick them up and donate a slab of something thirst-worthy.... :thumb
[ Edited on 16/11/2005 by Pretty_Blue_Bug ]
jnr356 ·
got plenty of wheels,roadworthy tyres could be a problem though!
WABaja ·
I would have thought sandblasting them might make the job a bit harder, as it doesn't leave a nice smooth finish to work with for polishing...
Wouldn't you be better off just "wet sanding" the current finish/coating off them, (unless of course it's chrome, in which case you don't have much option), but the rough surface that blasting leaves will need to be sanded smooth before they can be polished...
Just a thought, good luck...
PrettyBlueBug ·
jnr356 wrote:got plenty of wheels,roadworthy tyres could be a problem though!
You have plenty of wheels with Porsche stud pattern....?
Tyres aren't really a problem.... as I'll need to remove the ones I have on to get my wheels sandblasted, so they could go on the borrowed rims. Make sense? :P
PrettyBlueBug ·
WABaja wrote:I would have thought sandblasting them might make the job a bit harder, as it doesn't leave a nice smooth finish to work with for polishing...
I tried wet sanding a spare teledial rim that was crooked (it's the guinea pig so I know how my 4 will turn out), and it took forever to get the paint off, and even longer to try getting the undercoat off. My bf ended up getting it sandblasted and afterwards he sanded a section, and it came up alright. I'm going to finish it off and then polish it, so it'll give me an idea of how long mine will take!
Mad Manx ·
get them water blasted... ideal painting finish then
PrettyBlueBug ·
Mad Manx wrote:get them water blasted... ideal painting finish then
But I don't want to paint them...... :P
oval TOFU ·
You doing it all yourself?
[ Edited on 15-11-05 by oval TOFU ]
PrettyBlueBug ·
Yep, or atleast I will if I can borrow some rims. 😁
jnr356 ·
set of cookie cutters do?
jnr356 ·
or 15 inch 928 phone dials
mmm...neeed beeeer!!!
killakornkobb ·
i'd reccomend paint stripping them laura.. then wetsand
PrettyBlueBug ·
killakornkobb wrote:i'd reccomend paint stripping them laura.. then wetsand
I was wet-sanding using thinners, still took forever, and that was just for the paint. The undercoat is stubborn as all #&^% !
PrettyBlueBug ·
jnr356 wrote:or 15 inch 928 phone dials
15" is perfect! They're not buckled or anything....? They don't have to look immaculate..... you can u2u me if you like. 🙂
killakornkobb ·
get some paint stripper from supercheap, some dishwashing gloves, and a $2 paint brush
slap the stripper on, cover with a garbage bag, wait 20-30 mins, pull the bag off, and if u have a gerni - blast them.. if not, use a paint scraper, to get all the bubbled paint off, then hose it down with water, to neutralise the acid
and u'll have 95% bare metal HEAPS easier to wetsand.. and easier than a sandblasted surface
PrettyBlueBug ·
killakornkobb wrote:get some paint stripper from supercheap, some dishwashing gloves, and a $2 paint brush
Is this tried and true?? Will it get rid of the stubborn undercoat too? If so, it could be worth a go... thanx! :P
killakornkobb ·
i'v done it to get 3 golfs completley back to bare metal at work.. it works for me 🙂 if u have trouble i can come around and give eden a hand 🙂
pyr0 ·
scuff the paint on there first with a ruffish paper 😉 like 120 or 80 grit 👍 then apply the paint stripper.....make sure u dont get the stripper on you cause it burns
killakornkobb ·
haha so true.. my armis still burnt from the last golf we did 🙂
PrettyBlueBug ·
killakornkobb wrote:i'v done it to get 3 golfs completley back to bare metal at work.. it works for me 🙂 if u have trouble i can come around and give eden a hand 🙂
Eden's not helping me though... I wanna do it all by myself! :P
killakornkobb ·
sorry - i assumed he'd do the do the dirty work :P
paint stripping is the way to go🙂 but u do need to be careful of getting it on your skin - big ouchies
give me a yell if u need any help
PrettyBlueBug ·
Tehehe, I'm not afraid of getting dirty...
Thanx again for your info Damien, much appreciated! 😁
Now just need to find that nice soul with rims I can borrow....
