Quick shift for bay bus?
https://forums.aussieveedubbers.com/threads/46110/quick-shift-for-bay-bus
I want to fit a close ratio shifter to the Helbus.
I have looked on the Flat 4 website and they don't list a type 2 elimimator shifter.
Comments appreciated on these or other brands. Scat, Empi?
The shifter must be suitable for a bus, and do not want a shifter with a big T handle.
I have rung some places and get varying answers, so I thought I would get some feedback from owners who have had them fitted.
MickH ·
Get a SCAT one from Custom Offroad....works well for me!! You could always unscrew the "T" handle and install something else?
I like the look of the Empi shifter.
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC20%2D3593
Is the Scat one similar?
Hmm this is a Scat one?
http://www2.cip1.com/PhotoGallery.asp?ProductCode=C15%2D80503
Not so keen on the extra handle for rev lockout.
pyr0 ·
i have the empi one its awesome 👍 really easy to fit and shortens the shift throw by alot, not to mentions tightend the gear stick feel as well (less slop)
bus914 ·
there's always the $10 quick shift kit, that retains your original shifter. you don't need to cut the floor mat either.
Hmmm I do like the look of the empi one, and it would be good to have all new parts.
Lobus, can you get a closer shot of how much of the mat you had to cut? Or anyone?
Our mat has a couple of cracks just around the shifter anyway.
pyr0 ·
the bigger hole isnt too large i think i cut mine at 2-3cm each side 👍
Lobus, You going to DOVW? If so I will check out your shifter there.
Brad ·
I have a Scat one and have found them to be the best on the market for the money. If you get a Empi one make sure you have a look at the quality of it. In particular the wire that goes to the reverse lock out from the trigger. I have had a few brake and leave people without reverse, that is one big advantage on the Scat it has a solid shaft running to the lock out plate.
Can the T be removed and a ball put on ?
Mick H wrote:Get a SCAT one from Custom Offroad....works well for me!! You could always unscrew the "T" handle and install something else?
MickH ·
Helbus wrote:Can the T be removed and a ball put on ?
Yes.
vwtyp2 ·
go the Scat.
2nd best there is.
