FS NEW 1600 CC TWIN PORT WITH 040 heads * SOLD
https://forums.aussieveedubbers.com/threads/46123/fs-new-1600-cc-twin-port-with-040-heads-sold
seagull ·
Seagull neil
Perth wa
sold
Item , new 1600 cc twin port motor up right type , fitted with 040 heads , s&s headers & ally mufflers .
Motor has not been started >list of items as follows
Crank machined fist over size
Conecting rods machined
Heads had done around 1500 ks , I had these stripped down and rebuilt any way , the heads cost me $800.00 in the end .
Motor case was from a semi auto bug , I had the case inspected & cleaned .
New bearings seals ect
New 1600 cc pistion & barrels
New stock cam shaft
New lifters
New bosh alternator & pully & fan belt
New 009 dizy
New ally pully
New HF oil pump
New Burg type deep sump & never leak 316 ss filter cover
New fuel pump
New spark plugs
New spark plug leads
New chrome pully cover
New S&S dragster headers & ally mufflers
carbs included >1 x pic 34 stripped bead blasted > comes with new service kit .
1x pic 32 stripped down looks ok
Sold
I have a crate going to Brisbane next week & can ship the motor in this should some one there require
* a small charge of around $75.00 would apply *
Collection only ( address will be provided )
cheers seagull
[ Edited on 18-11-2005 by seagull ]
[ Edited on 19-11-2005 by seagull ]
1958 ·
Hi, I am very interested. Would you be able to ship the motor to Adelaide?
If you can, for how much?
Thanks Steve
seagull ·
Yes Steve , I can as long as you have a work address for delivery point > If you do not I can get the freight to Treliving engineering supplies .I am not sure if this is near you o,Halloran hill sa 5158 > you could collect it from there . As I send freight to them from Perth all the time .
I can not see it to be more than $120.00 , for the motor in a well packed crate .
I will send you my home number ( u2u ) Top right of your screen .
Cheers Seagull Neil
