EJ20 T just what kind of power are you getting ?
https://forums.aussieveedubbers.com/threads/46293/ej20-t-just-what-kind-of-power-are-you-getting
gull ·
I was looking at the posts , trying to see what power out put you guys are getting with the ej20T motor .I see mats has a differant turbo , so just what is a stock ej20T getting down at the wheels please .
has there been any gains on after market ecu ?
& the water cooled coolers are these any good to keep ?
have you fitted the cruse control units from the front cut ?
cheers seagull
speedster356 ·
stock ecu running 16psi = 191 hp @ the wheels auto turbo (tdo4)
aftermarket ecu still rich (10.4 : 1) running 16psi = 238 HP @ the wheels stock manual turbo (tdo5)
air/air ic.
Jak Rizzo ·
http://www.thesamba.com/vw/gallery/pix/205015.jpg
Mine , 94 ej20T,
All standard bar pod filter, Microtech LT8s, standard TD05 running 8 ponds boost max, small 2.5 inch exhaust with no splitter yet for wastegate.
Pretty flat tourqe curve as well.
Paul's should make more then mine, his 3 inch exhaust with wastegate splitter is a work of art.
Matts should make more as well, 3 inch exhaust, ball bearing turbo & boost control. It's already a scremaer!
regards
Jak
boof2332 ·
I will let you know next week hopefully.
I have a relatively small turbo in the vf24, which was used in grougp n wrx rally cars. makes full boost on a dyno at 2800. If you hit it hard from the start, it doesnt feel as if its got a turbo, just lots of balls. I had a sort of run with a GTi golf yesteray on the long hill going into Dural. I couldnt quite catch him due to a slight sideways drift..spinning 1st, 2nd, 3rd and 4th. It only stopped when I backed off to let him in at the top.
I'm hoping for similar to Peter, at about 250 atw with similar boost.
Matt
seagull ·
going to the other side :vader
