Enamel or Acrylic?
https://forums.aussieveedubbers.com/threads/46325/enamel-or-acrylic
rupewrecht 路
Hey peoples
i'm in the process of prepping my 62 beetle to be sprayed matt black
a (professional) mate who is going to spray it for me said i can use enamel or acrylic.
what's the better option, and why?
also, will the flat black mark much?
thanks for any clues 馃檪
helbus 路
It's your choice what you want to paint it in, here is an article explaining the differences. There is no simple answer to a better option.
Make sure you read this article properly and I will test you on it later
http://www.oldholden.com/possible/index.php/Acrylic_Vs_2_Pak
And yes the flat black will mark much
rupewrecht 路
haha a test?
thanks for that article.
so, seeing as the flat black will mark, is there such a thing as a low sheen clear that could be used over the top?
as it's probably going to be sitting outside most of the time and subjected to a fair bit of weather.
helbus 路
The problem is clear is a shiney surface in automotive paint. If you add flattening base to it, you have just made it exactly the same as the black paint underneath. Clear is the same as solid paint.
If you painted your car with gloss black and put a coat of matt clear over it, you would have the same effect with the same marking capabilities. If you polish the scratches out, it will shine up just in that spot to a certain degree.
If it is going to be subject to fair bit of weather it will deteriorate much faster than a gloss finish. The more matt you add to a paint, the more you dilute the protection properties. Matt is a product with no protection, so it dilutes the anti UV etc. in normal paint.
rupewrecht 路
Ah fair enough. I thought there might be a way around it, but i guess not!
Thanks for the info 馃檪
crewcabconnection 路
matt black beetles are soooo yesterday....lol...how about 2 pac he said being oppositional...
