Suzuki GN250 question ( Need help )
https://forums.aussieveedubbers.com/threads/46369/suzuki-gn250-question-need-help
seagull ·
I was draining the oil & have undone the oil pressure relief valve can some one please tell me the correct way the spool fits back in with the spring .
cheers seagull
tassupervee ·
hehehehe the same way it came out...........................................
Sry M8, I could not help it!!!!!!!!!
:kiss
L8tr
E
Did you find one that doesn't blow smoke? They are a hardy little 250, and great for a learner.
seagull ·
This one is going good
Just need to find the correct way to put the dam oil pressure pistion back in .
:alien
Typ-152 ·
on my micro fiche it shows plug , washer , spring , stopper
are these the same parts thet you are trying to fit.
Jason
seagull ·
Correct Jason ,l I need to know the correct way the pistion fits in , cheers
seagull ·
The pistion is like a The letter T
Typ-152 ·
upside down T so it's on top of the spring and the domed part to the top
it is described on the fiche as (STOPPER ' neautral)
hope this helps, Jason
seagull ·
Jason :beer
Thank you kindly !
Typ-152 ·
just a reminder with this type of motorcycle is check oil level regulary and regular oil changes
and try not to use fully synthetic oil. use mineral oil only.
jason😵
seagull ·
ok cool
Jason is there a gear box section that requires oil ?
or is it a shared box / motor ????
doing the oild now
cheers seagull
seagull ·
I need to get a manual :jesus
seagull ·
help ( ! ) :alien
helterskelter400 ·
shared motor and transmission.
treat it nice and it will last forever
Typ-152 ·
just like helterskelter400 said😵‍💫
seagull ·
thanks , I make sure he does :tree
Desert Moose ·
seagull wrote:thanks , I make sure he does :tree
Right got it going now lets go kill it............lol
:P
seagull ·
if you sit on it you will , you big MOOSE LOL :P:P
