Well after what I think has been at least 4-5 weeks of re-assembly i've got my car drivable again.
The shell was re-sprayed again to fix some of the flaws in the previous paint job that was done about 1-1.5 yrs ago. Most of the car was re-sprayed as I understand it...
As for the latest upgrades....
1. Removed the 12x12" oil cooler and installed 2 x 12x6" HKS alloy oil coolers with ducted 7" fans.
2. Traction brace, made from a Nissan S13 rear strut brace and 2 x Nissan S13 TORQUE bars (D1 suspension components cheap off ebay). I love mentioning this cause I know how much it pisses off Nissan owners that I have D1 suspension parts on my VW.
3. High temp header wrap... The cheap stuff I got from a truck parts place had partially melted to solid glass. Hmm its a little warm there...
4. New intake system. Tired of having leaking gaskets I decided to make a 100% bolt together flanged intake system. There is only 3 hose joins now. Two on the intercooler and one in the middle behind the fan shroud that links left to right. Part of this meant making new carbon fiber heat shielding to cover the turbo and stop the engine sucking air from under the car.
5. Fuel system is now 100% 3/8" stainless braided speedflow using -6 fittings. Flows enough fuel for a safe 800hp... overkill anyone! I've still got to update my pump to a bosch 600hp unit, and the billet aeromotive fuel pressure reg got lost in freight but thats coming too eventually...
6. SOUNDPROOFING! I've lined the inside of the car with 1/2" thick sound proofing and have some of the carpet kit installed.
I took some pictures this afternoon after washing the car at the top of some local hill where the land prices start above the $million mark. If anyone would have been home I'm sure the cops would have been called when I stopped in front of their house and started taking photo's. :P
So here they are... they are all high res pics. I'm going to try and get the car up on a hoist soon so I can photograph the oil cooler, traction bar system and under side of the chassis. Its a very tight fit, but works a treat and is a heap better and cheaper than importing one from CSP in germany.
As for the tune i'm still running 5lb boost while running the engine in and i'm starting to get used to the power its making. My 1641 turbo made power from 3500-7000, and this 2332 turbo makes power from 1000 RPM to 5000 (so far) so it seems.
I'm still planning on running 7lb on for a mild street tune. I've decided to run the boost control directly from the engine management so I can pre-set the boost from 7lb-12lb at any RPM point just by arming a boost control output. This should help reduce drive line breakages and provide better launch controlability too. Without it, it would hit 12lb boost by 2600 RPM and i'd be sideways and lock to lock while trying to drive a straight line.
Enjoy all, I can tell you that I sure am!
[ Edited on 27-11-2005 by iswinkels ]
jvl054 ·
Very nice!!!!!:thumbJVLRacing
Craig Paton ·
If I get up your way sometime in the future, I'll have to book a ride!
Never been in a turbo Volksie! Especially in something as Awesome as this!
Looks Great!
[ Edited on 28-11-2005 by Craig Paton ]
Gracey ·
Awesome, looks great!
Turbo54 ·
Fantastic Ian, lots of work and time and finally you might be happy until the twins come!
Good for you, looking forward to seeing some underneath shots.
Turbo54
reub ·
SWEET DUDE!!!
looks real nice. You're hard work and dedication is astounding!
A huge thumbs up :thumb
Dasdubber ·
Awesome stuff Ian - looking absolutely fantastic!
2443TT ·
Turbo54 wrote:Fantastic Ian, lots of work and time and finally you might be happy until the twins come!
Turbo54
Not so sure about the twins anymore. Yes i've gotten one gt17 and it will fit on the drivers side so twin gt17's is possible. But I've noticed that garrett have released a gt2832, 370hp turbo that uses a 0.6 compressor housing so it wouldn't run out of top end quite as quickly as my 320hp gt28.
Also, the GT28-320 might still be close to enough. i'll have to see how it goes when the boost is wound up a bit more. As it drives, I suspect the rev shift point will be about 5000 or 5200 rpm at the most. There's no sense in reving it anymore because it has so much bottom end torque and its hitting full boost so early.
pete wood ·
What's wrong with you Ian? of course you need to be going sideways at 2600rpm whilest trying to drive in a straight line. Young people these days! 😂
But seriously, the car looks awesome. great to see it finished and all together. Also looking forward to what it does down the strip. 😉
hellbugged ·
great stuff......you might want to look at a qucksteer coupling for your steering.....imagine one full turn from lock to lock, a good way to catch that tail!. they have been used before and i know where to get you one if ya want.
2443TT ·
Na, not a fan of the quick steer kit. It makes the slightest wheel movement mean your wondering all over the road when your at speed. Especially above 140km/h or so, not that ive ever done that before....
Hey dumone, why the Hellbug engineering logo as your icon... What ever happened to Jeff and Shimmo?
hellbugged ·
iswinkels wrote:Hey dumone, why the Hellbug engineering logo as your icon... What ever happened to Jeff and Shimmo?
They're both alive and well, i spend a couple of days out at Jeffs every week, lots of goodies there still!!!! and Shimos still doing a bit, he has just rebuilt a box for Jeff
no slow 63 ·
Very well done! I like your work.
2443TT ·
A brief history... I have of about 4 months ago installed a 2332 turbo/intercooled engine into my street car. The engine goes great but suffers from one thing. That was when the car was stationary, the hot air being expelled from the porsche style air cooling system was being picked up and recirculated thru the oil coolers by their thermo fans. When the car is in motion it sits happily at 83-90 degrees on a hot day. This tells me my coolers are of an adequite size, its just they can't get enough cool air to circulate when the car is stationaty to maintain a constant air temp.
The car has twin 12x6" alloy coolers with shrouded in 7" fans pulling the air thru them. They were mounted under the car on a 45 degree angle following the floor line under the back seat. I had to install two coolers because my traction brace gets in the way of installing just a 12x12" single cooler.
My car uses 3 electric pumps, and 3 thermo fans to provide cooling for the water/air intercooler, turbo bearing housing and of course the oil. Yes I circulate oil thru the two coolers with an electric pump (like a v8 supercar does with diff and tranny fluids etc). The engine also has a 32mm pump full flow oil system with an Avaid external oil pressure regulator and return line system to keep oil pressure under control. All electric pumps and fans are controlled by the ecu also, but they rarely tun off during driving unless its a cold and/or raining day which is obviouslly improving the cooling capability of the system. On/Off triggers are configured in the ecu based on temperature information received from sensors in the engine.
So i'm thinking about my stationary heat build problem recently when tuning a mates Nissan S13 I noticed that the fan cuts in and out as is needed. This too is controlled by the engine management. When the car is driving, the fan is never on, as the flow thru air is more than sufficent to provide cooling. As simple as this sounds, I doubt that many of us had thought to postion their coolers in such a place that the fan's on them don't have to run, except for those of us with sand rails or course!
So this got me to thinking... If I could place my oil coolers well enough so that they get a huge volume of cool air passing over them I could likely turn off the fans too, and just run the oil circulation pump to keep things cool. This would put less load on my electrical system too, and as the coolers would be better placed I would kill 2 birds with one stone and solve my hot air circulation issue at the same time.
So this isn't a new idea by any means, I saw it first in turbomania and they called it porsche careera style oil coolers (mounted up front under the front guards. My problem was that I wanted something solid to mount my two fancy HKS oil coolers on, plus still have the fans on them so they'd keep things cool when I was stationary.
What I came up with is a cradle that bolts on to the front sway bar mounts and the front bumper, and provides solid mounting for the oil coolers. It would also make a great mount from a front spoiler and allow me to duct air straight to the coolers. The front brace is 4mm steel flat bar so its pretty strong and will also serve to provice a little protection to the front valance from speed bumps etc, though I avoid those most of teh time. The whole thing turned out way better than I was expecting.
Here's some pictures...
Unfortunatly the 8 meters of hose I bought turned out to not be enough to finish the job, plus I need one more 180 degree -10 speedflo fitting so its not going to be finished till next week.
I'll take some more pics and keep you all posted as to how it performs. With any luck I'd like to have the car drive with no fans running, plus have the oil pump cycle on and off between 80-85 degrees. We'll see soon.
[ Edited on 14-1-2006 by iswinkels ]
Like what your doing. I don’t think there is any better place to have an oil cooler, at the front in nice fresh air.
If you were ever brave enough to drive in the rain they would get a nice water spray.
2443TT ·
Yep and the fans would never run, and the oil pump will cycle on and off like a thermostat! Like modern technology nearly...
pete wood ·
Wow, you don't do things by halves Ian...:duh
Looks really interesting. Kind of reminds me of the stuff I've read about Moby Dick's (935 porsche turbo) engine. Only I guess you're not aiming for 1000+hp and a welded diff.😉
I spose your gunna put some fully sic mesh across the oil coolers to protect them from sticks and that?
Just a thought, and not meaning to stir, but with all this trouble cooling it, and the coolers mounted up the front like they are, wouldn't some sort of water cooling have done the trick in the first place?
Anyway, love the setup, it's more and more german look every time I see it 👍
2443TT ·
Only after I assembled the engine did thread start to appear on shoptalkforums.com that began to discuss encasing cylinder heads in water cooling jackets. This is fairly common practice for the autocraft heads, and someone has done it with comp eliminators like I have too.
There are also some aircraft engine manufacturers that are using a vw style casting but water cooled the heads. The are the ideal thing for a forced induction vw for sure.
In the end though, my cooling issue was caused by the coolers re-circulating hot air that had been exhausted from the engine's porsche 911 cooling system. It would only get hot when idling and stationary. I could have ducted fresh air to them and left them where they were if i didn't also have a 3 bar traction brace under the back of the car also.
As you can imagine it was quite cramped, and was basically impossible to work on without disassembling the car. Now with the coolers up front its at least 1 step back towards being practical...
jvl054 ·
Yep that will work:thumb you could of also dunn a prefab floor placing of the oil cooler and ran the air over the top aswell.By doing this you can trap cold air into a box section witch has to force cold air around the cooler.Thats my set up! but yours is effective.good job.JVLRacing
2443TT ·
So you've got FMOC's too?... Note my ricer style lingo... Front Mounted Oil Coolers... 😏 I am just too cool for rice?
Seriously tho, do you have any pics of your oil cooler setup JVL054?
jvl054 ·
iswinkels wrote:So you've got FMOC's too?... Note my ricer style lingo... Front Mounted Oil Coolers... 😏 I am just too cool for rice?
Sorry ian not sure what FMOCs stand full.I dont have any pics.If you have a camera phone i send some to you.u2n me your number go from there.JVLRacing
2443TT ·
Surely you've seen it... its cool as for the rice guys to turn everything into an acronym. Its spawned entire product lines for stickers that probably make as much for the part companies as does the sales of their parts!
Apexi, 5ZIGEN, AVCR, eBoost, HKS, OSGiken, mugen, trust, bla bla bla... There's a whole community of honda owners out there that use these stickers to enhance the performance of their cars...
FMIC is short for front mounted intercooler... ie what wrx owners put in the front fiberglass replacement bars so they can go faster because the top mounted intercoolers are crap, not to mention being in the wrong location... I guess they forgot that heat rises...
jvl054 ·
iswinkels wrote:Surely you've seen it... its cool as for the rice guys to turn everything into an acronym. Its spawned entire product lines for stickers that probably make as much for the part companies as does the sales of their parts!
Ok FMIC not FOMCs:PI dont know if you buy Zoom mag at all but 2 year ago i had frontcover and there was a photo of the way my oil cooler was done.Ask Reubs he might have the mag of it.JVLRacing
71superbug ·
which issue was it in? wouldnt mind backordering a copy of that 🙂
Anthony
jvl054 ·
71superbug wrote:which issue was it in? wouldnt mind backordering a copy of that 🙂
Anthony
Hi Anthony,No 72 the car has change alot since.It runs a fullcarbon floor etc.JVLRacing
71superbug ·
was it on the cover wen it was green? or orange?
Anthony
jvl054 ·
71superbug wrote:was it on the cover wen it was green? or orange?
Anthony
Green&yellow.JVLRacing
56astro ·
What's the latest, haven't heard how the beast is going!
malcolm ·
great work on the car,have you thought about going to solid lines for the oil coolers now the set up is working.
are you happy with the pwr water/air intercooler and the electric pumps used ,could you use one to scavenge oil from the turbo if youhad the turbo mounted low.
[ Edited on 1-9-2006 by malcolm ]
2443TT ·
Hi Everyone,
The cars scary fun to drive and now its run in i've started to rev it a little more and also added a little more ignition while on boost.
The cooling system is going to have some refining done to it soon as although it works the distances involved with pumping the oil means the temps fluctuate a fair amount.
So the immediate plans are first to do another engine rebuild to change the oil pump to a 38mm revmaster aviation pump which has a built in relief valve on the cover and to change a few other things. I've ordered a set of CB performances's tool steel light weight gudgen pins and a few other bits too.
The two front oil coolers are going to be converted to coolant, and the coolant will be pumped thru a C&R radiators ex-nascar oil to water heat exchanger. This will make oil temps more constant and allow me to simplify the coolant system a little. 3 radiators and electric 2 pumps instead of 5 radiators and 3 pumps like it currently has.
The turbo system is being upgraded too. It will either end up as a twin GT1752 system or twin GT22VNT turbo's with the turbo's mounted in the parcel shelf area, and a new rear bolt in firewall section will be made also. I am planning to start these upgrades over the next couple of weeks.
The PWR intercooler is great. The only problem is getting enough airflow to the radiator to cool down the coolant. I will probably end up front mounting a radiator in front of the front beam down the track to take advantage of that airflow under the car to help lower air intake temps. With the current placement of the radiator under the left rear guard air temps top out at about 45 degrees on the hottest of days, so its pretty decent for where its located.
I'll be sure to start a new thread when I start working on the twin turbo setup and the new cooling setup too.
reub ·
You're mad dude....and I love it!
Great to hear about the continual development of this awesome car.
malcolm ·
heres a twin turbo type4.a porsche place in vic done 1 a few years back and it had 750nm of torque.
2443TT ·
That looks sweeet! I like the intake plumbing, it looks nearly identical to my current setup, except i have a PWR barrel inter cooler hung underneath it, and a merged T off to the right hand side.
