Does a/body know where I could get one of those Rubber protectors that sit in the cupped area for trolley Jacks to protect the pan when raising the car? ❓
I've seen them before, don't know the exact name! 🤪
Been to Auto Pro & Super Cheap, nothin! 🙅
Thanks C.
[ Edited on 29-12-05 by Craig Paton ]
Craig Paton ·
I believe they're called "Jack Pads"!
Purple Martin ·
A piece of plywood works a treat!
Craig Paton ·
Yeh been using that with rags for years.
Want something better for "MY PRecious"!!😘
Old Dubber ·
What size would you be after?
I have some red neoprene block which may do the job
Craig Paton ·
Hey Grahame
It needsd to be roughly 128mm in diameter and the debth varies because of the internal cone shape.
Thanks! That's exactly what I'm looking for.
Does a/one know if I can get these in Aus.
Dak-A-Tak ·
Craig!!!!!!!!!!!! Does this mean your car is going to see the light of day soon! ( new motor did santa drop it off ) Pics would be nice ( i don't believe it ) My jack pad I made from solid rubber (12mm) then I die grinded small holes for the jack crown ( 5mm deep ).Rubber from Clark's Rubber. Very cheap.
WA Volksrodder ·
next time you're driving down the highway and on the side of the road, you see the tread that has been thrown from a punctured truck tyre, stop and pick it up, take it home and cut off a bit to suit your jack...
done and ..........done...
Craig Paton ·
Dak-A-Tak wrote:Craig!!!!!!!!!!!! Does this mean your car is going to see the light of day soon! ( new motor did santa drop it off ) Pics would be nice ( i don't believe it ) My jack pad I made from solid rubber (12mm) then I die grinded small holes for the jack crown ( 5mm deep ).Rubber from Clark's Rubber. Very cheap.
Hey Pete
Engine is not ready as yet! It's behind a Porsche eng & an aircraft engine!
Shouldn't be to far away though. My car saw the light of day twice this year, had 2 washes and polishes!!!!!! :o
'06 will be a different story. 😁
Gota learn to drive the thing all over again....it's been almost 6 years!!:duh
I would still like to buy one of those Jack pads.. they're so prurdy!
Volkswagenboy ·
I wouldn't mind one! I was given a chrome racing jack for xmas, it'd go perfect with a jackpad!
Old Dubber ·
Craig,
I sent you a U2U, but did not get a reply????
(I have some red neoprene block which may do the job)
Give me a ring 3355 7943
Craig Paton ·
Hi Graham
I didn't get your u2u! I'll call you on the weekend
