Ah, you can always pick a VW driver in a group.
Was in some training for work yesterday, we were programming a PLC system and running it on some new Ubute wizbang gear we are using at work. Needless to say it all turned pear shaped. An hour of hair pulling and we discovered were were in desperate need of a 120ohm resistor, where do you find one at 6pm at night?
No luck finding one, so I ducked outside, grabbed the multimeter and started searching, and sure enough the idle jet solenoid in the carbie (type 3) had a resistance of 100ohm, good enough to run our test. Hooked it up and away we went!!!
Ah it makes you feel good when a trusty old VW saves the day, even with modern electronics
Richard
:thumb
Andy ·
