HELP! flat spot on take off, daily driver
https://forums.aussieveedubbers.com/threads/46781/help-flat-spot-on-take-off-daily-driver
kroozzn63 ·
my ute has a flat spot on take off and when i put my foot down it splutters then takes off.
only when i accellerate it spultters if its a bit hard on the pedal otherwise ok but i drive it all day every day i need help so i can feel ok driving home today "NOTE" i have pulled out the idle jet and theres no gunk in there
jo_tas ·
From experience fixing stuff on my type 3... check the fuel pump on the carbie(s) and your vacuum advance, if you have one.
kroozzn63 ·
thanks check it does that mean tap it with a shifter?
Is this something new or always there??
What is the motor / carb / dizzy types???
PrettyBlueBug ·
My Bug was doing this, and it was the points.... are yours all good?
jo_tas ·
Sorry i meant accelerator pump... i had the same problem with my car and it turned out to be that the accelerator pump wasn't pumping in enough fuel...
64vwmark ·
Had a similar problem recently, it turned out to be a vacuum leak.
crewcabconnection ·
Bendon...Kimm at Indian has flat spot remover. He's called Damien.
