G'day people, I am looking for a Gene Berg Intermediate gear box mount the one that has brackets that are welded to the frame horns and attaches to the gearbox itself to stop the breakage of the nose cone, i would prefer the rubber mount type, does anyone know if these are available from dub shops here or would i have to order form the bergs themselves. It is for a IRS transmission. Need it for the type 4 engine I am building. Cheers Damien.
[ Edited on 13-12-2005 by 66deluxe ]
[ Edited on 14-12-2005 by 66deluxe ]
66deluxe ·
just bumpin
They are not hard to make if your that way inclined.
HGFS ·
That's what I thought, it doesn't look that high tech. Do you have any dimensions or know what thicknesses everything is??
u2u Alex Holzl
V Force had something very similar
When I made mine i used bay window Kombi mounts, the berg ones use, the ones on top of the bell housing. I made mine using 40 mm square tube, didint bother making it like Berg with the round welded to the U channels. I made a cardboard template and had a 1/4 steel plate profile cut for the bit that bolts to the transmission.
66deluxe ·
Cheers guys for the info I think making one will be the go, will let you all know how it turns out. Cheers Damien.:beer
