Help needed with S bug fuel
https://forums.aussieveedubbers.com/threads/47056/help-needed-with-s-bug-fuel
Yogie ·
The fuel pipe that goes through the tunnel at the fron of the car has been broken off on my 1302 S bug.
Does this mean I have to replace the whole fuel pipe and if so, how do you do it?
Will a standard beetle fuel pipe fit?
Yogie
Not an easy job.
Fuel line needs to be steel and i believe
1) isnt allowed to be run in passenger cabin
2) not exposed to damage - ie not run under car. That is why it was run inside the tunnell.
The VWMA editor was/is doing a similar job on his fix up in the magazine.
Some good pics in the last edition
It does involve an angle grinder and large holes though :duh
You aint gunna fix it on a lazy Sunday
Yogie ·
Thanks Bizarre. I haven't gotten that far yet in the magazine. Will have to get reading. I did find a site on the net that explains it in detail though. Looks like a decent sized job ahead of me.
Yogie
You can get access to the fuel line from the front of the pan, there is an access cover that unbolts. You would need to really put some thought into making a safe way to extend from the broken line up to your fuel tank. The other way is to cut the tunnel open and fit a new tube.
