country buggy info pls..
https://forums.aussieveedubbers.com/threads/47139/country-buggy-info-pls
h ·
hi all
ive tracked down a sweet country buggy that may come my way if i play my cards right..
anyway if any body can enlighten me/us about these type of vws it would be appreciated muchly.. :thumb
cheers paul
Purple Martin ·
Good info here:
http://members.netro.com.au/~vwcc/cb.htm
subibaja ·
what do you want to know
MikeM ·
subibaja wrote:what do you want to know
I don't know what h wants to know but I want to know the factory specifications for the front and rear track of a country buggy.
Same wheels and g/box etc as split Kombi - which may be easier to find. No, I don't know...!
MickH ·
All the important info is here...
http://www.clubvw.org.au/country_buggy_takes_all_in_its_s.htm
h ·
thank-you..
i should of been more specific..
just general specs, like built from when to when, which interchangable bits etc etc..
cheers guys..
h
58camper ·
The detailed Country Buggy story is at;
with production details included. If you need further detail let me know.
The question around front and rear track is
Track at front- 1376mm (54.1in)
Track at Rear- 1360mm(53.5in) at 0 deg camber
Toe in;unladen 0-2mm (0 -.08in)
Full loaded 2-5 mm ( .08in .2in)
By the way- recommended tyre pressures is 16 psi front and 26 psi rear on 4J X 15 drop centre rims.
Countrybuggybill
h ·
cheers for that.. sweet 😁
