new engine 4 sale
https://forums.aussieveedubbers.com/threads/47152/new-engine-4-sale
RodPenrose ·
I have a brand new engine for sale due to a change of plans . This is an empi aluminium case , an 84mm CB performance race crank , 5.880 eagle rods with arp 2000 bolts ,94mm mahle pistons , Jay-Cee long barrells , Fk 98 cam , scat 1.4 pro rockers ,scat lifters , dual tapered pushrods , berg wide sump , melling steel oil pump , empi steel full flow cover , Jay-Cee pushrod tubes , comp. eliminator heads with 46mm x 38mm stainless valves and chevy springs ported by A J sims and flowed by Dave Butler with 234cfm @ 600 lift and 25'' pres. The engine also has a lightened flywheel - 4puck - stage 2 kennedy plate , 1 3/4 ceramic coated bugpak exaught , porsche cooling system , and matched ported manifolds with CB 48mm throttle bodies and a Motec engine management system . The comp. ratio is set @ 8.4:1 and all of the above parts are new and it has not as yet been started . I will estimate the engine will produce about 210 hp and would like to sell as a complete deal for $ 11,000 . thanks ROD.
dangerous ·
Show 'em the inlet ports Rodney!
Doug Sweetman ·
far out thats bargain central !
Why couldnt I win lotto just once ?
good luck with the sale
sean68 ·
don't tease me
i just bought a chrissy present for the 68 last week
RodPenrose ·
Here are some additional pic's of the heads and short block during assembly . Dangerous Dave Butler could shed some more info on the Heads and flow figures if required . The engine has also been balanced , comes with a full compufire ignition pack and is 65mm wider than a stock 1600cc engine , ROD.
