Performance Heads
https://forums.aussieveedubbers.com/threads/47483/performance-heads
shiftyvw ·
I have two sets of Type 1 heads for sale....
Brand New pair of heads, 44 by 37 valves, Good dual springs (berg i think) professionally ported. 94mm bore long reach plugs.
$750ono
the other is a set of used 40 by 37 heads. 94mm bore Nicely ported, $300ono-sold
call owen on 0413 266 808
[ Edited on 7-1-2006 by shiftyvw ]
rufbug ·
any cracks in the 40 x 37s
shiftyvw ·
From memory the 40/37s may have small cracks between the seats, no cracks around plugs though. ill check today.
shiftyvw ·
the used 40/37 heads are 043 castings and do have very fine cracks between the seats.
shiftyvw ·
used heads sold, still have the new 44/37 heads
shiftyvw ·
Bump!
Golde60 ·
are the new ones 044s?
shiftyvw ·
No, not 044's.
shiftyvw ·
bump!
hellbugged ·
Golde60 wrote:are the new ones 044s?
what are they then?
jakjones ·
043 castings as it says above
hellbugged ·
jakjones wrote:043 castings as it says above
check again, read carefully
jakjones ·
I do need to read more carefully, sorry.
hellbugged ·
i'm just kinda interested, they sound nice.
shiftyvw ·
No they are not 043's that was the used set i had. The new big valved heads have a casting number 04* where the third number has been ground off. They have long reach 14mm plugs, and are cast with more meat behind the chambers (looking though the fins). but they do not have the filled intake like a cb 044. Thats all i can say!
They are a nice set of heads, would go nice on a hot street motor etc, the port work is very nice and will probably work quite well for drivability, but for max power i went with a set of wedgeports for my motor which will really be drags only, as the ports are much bigger.
hellbugged ·
welded?
shiftyvw ·
no not welded, i would describe it as a round port.
