It looks like I'm going to go water cooled.....:puke
I'm looking at a 93 Caravelle, but I've never had anything to do with them.
Anyone want to tell me what to look at? Where are the trouble spots? What noises I should listen for? Shit like that.
DOUBLECAB ·
Spook wrote:It looks like I'm going to go water cooled.....:puke
:oHi Spook ..recently bought a T4 1998 double cab and went through the same dilema as U...had 92 T3 double cab previously.
Anyway for what my suggestion is worth (on AVD anyway) I was advised not to get a T4 earlier than 1997 mod....dont waste your time with the 2ltr..they are gutless....auto gearboxes.....have a spare $5000 sitting in the bank if they go.
and talk to " 20v kit car" or just ask your questions on that forum.
All the best.
cheers.
ragtopp ·
I got a 96 2.4 diesel 5 cylinder single cab. I got it cheap with 105000 on it, got a good checkover and showed up $2000 worth of service and repair items. Starter motors are weak, they slog out the bush in the gearbox, new starter had been re engineered to take out this fault. The dash electrics seem a bit suss on a few aswell with instrument clusters a real hard find second hand. Same as gearboxs, mine has now 155000 and the box has a few issues. The Diesels top out at 130kmph aswell,even though thats over the speed limit at 110kmph they are reving fairly hard. Fuel economy is good if you can leave it at 100 kmph tops. They are good daily drivers and it gives my aircooled stuff a break for the weekend.
Spook ·
A little more info;
2.4 litre petrol, manual. Just short of 280,000 kms.
Surely at that sort of mileage anything that couldhave gone wrong would have already.
byronbus ·
Spook, give steve a call 0400 356 057, if any one knows about T4s he does...
DOUBLECAB ·
Spook wrote:A little more info;
:oOr is just about to......didnt know they did a 2.4 petrol..is that the 5cyl ...if it isnt I suggest U drive the 2.5ltr 5cyl.
At 280ks if the engine & gearbox havent been overhauled I would expect the job is just around the corner.....but hey I could be wrong.
Btw the guy on the watercooled site is called steve.
Does the vehicle have any service history and are U able to talk to the people who did the service?
cheers.
Kombi_Rescue ·
t4 wisdom teeth! 93 model caravelle will have a few items to look out for ....if this vechile has been run on PULP the exhaust manifold will survive the test of time, non factory fit air con systems will be a constant source of grief...retro fit a factory nippon system which are by far the more reliable unit....autos can be a issue but most have had a rebuild these days 10-11 years on.check g/box mounts in the auto as these wear..check if regular cam belt services have been preformed along with replacement of cam and crank seals to avoid oil leaks....rear brakes are solid...very rare to even replace linings after 200k's....visual checks on water fittings at the cylinder head..these are plastic and can crack..but are cheap to buy....if its a manual check the gearbox oil level ..this is the most common fault in the t4 range as many boxes run dry ....overheat and become noisy..in general these are a tough van ..solid reliable and best of all SAFE....stick the jap crap where it belongs....go with the original people mover and keep the faith...hope this helps a bit cheers steve
byronbus ·
Good one grandpa t4 poobar...
Spook ·
Thanks Steve.
I was begining to think no one had a good word for these f#ckers.
Kombi_Rescue ·
to be honest more t4's do higher mileage than t2/3 in the drive train with less problems...maybe they lack a little character be when compared to apples they win hands down....highest mileage t4 I know off is 600;000ks a t3 covered close to 700'000ks and a t2 double cab 1 owner with 1.25 million k's fully doc...did I just shot myself in the foot...oh well I like em all !!!!!!!!!!!!!!
amazeer ·
engine in wrong end, oil filters impossible to change without making a mess, spark plugs pain in the arse if bullbar fitted, heavy buggars, nobody will wave, be careful backing into parking spots, they are a lot wider, much more comfortable and car like than your old truck, impossible to rebuild on a valla campsite. Wouldnt mind one myself.
Spook ·
This one's for Mel, my 73 aint going anywhere, & what I'm doing with the 57 depends on my mood that day..😂
But as it stands this guy has only had it for a little while & cant give me any info on work done. I may have to give this one a miss.
DOUBLECAB ·
U could always get it tested by the NRMA or your local VW expert.
Btw if he has had it only a short time....why is he selling?
Spook ·
That I do know. He bought it for his missus but she has trouble getting up into the thing, so he's got her a station wagon.
[ Edited on 7-1-2006 by Spook ]
DOUBLECAB ·
Guess thats always the risk we take when we buy 2nd hand and privately.
Bought my 98 doublecab on a Pickless auto auction over the internet sight unseen....with only questions asked off the auction house........had a few small issues to get a RWC but bought it well under market value and am getting $1200 back in GST because its for business purposes.............and it had a $2500 aluminium checker plate toolbox in the back for which I hope to get at least $500 back.:P
As Forest Gump said.....Life is like a box of choclates...etc etc.
hope your pick is a good one.
cheers:beer
kombiluva ·
Doublecab- My 1998 Caravelle GLS has 280K on the clock....and as strong as the day it came from the factory.....
has got another 200k in it before I look for a rebuild....just like the Taxi Caravelle that goes between Threadbo and Jindabine....had 500k on it about 2yrs ago....or the Synchro Ambulance running up that way as well....all with very high klm's.....and going strong....just one thing...do all your belts (engine bay) around the 200K mark...will save you a rebuild if the timing belt goes...
DOUBLECAB ·
kombiluva wrote:Doublecab- My 1998 Caravelle GLS has 280K on the clock....and as strong as the day it came from the factory.....
Hey kombiluva..... my 98 has 152Ks on the clock and if it got me to 280Ks without a rebuild I would be carrying on like Meg Ryan in "When harry met sally" (I think....bugger those rusty nails this time of the nite) ......
Had a T3 doublecab I bought with 12Ks on the clock and by the time I sold it at ....I think about 220Ks I had 2 lots of crankcase water seals go/fuckup at $4500 a pop....thats why, although being a VW owner for mega years, I adhere to the Forest Gump chocolate box theory on VW's.......U either get a good one or a bad one....nothing in between.......other folks have gotten 300ks on a T3 with no probs.
btw...U dont know where I can get a T4 owners manual at the right price as mine came without......and a workshop/service manual as well.
cheers/regards....:beer
Spook ·
So ya reckon grab it & let the chips fall where they may.
Fact is, I bought my bay knowing sweet FA about it, to the point where my neighbour had to show me where reverse was. 15 years & a hell of a lot of kms down the track, there isn't one bolt on it I'm not familiar with. I help others with theirs now.
I know this thing is cheap, I've yet to see one under 10k, & for it's age it's imaculate cosmetically.
BUT; theres a lot more spandoolies involved when one of these pops it's cork. Being cheap don't make it a bargain.
If they are half as reliable as the bays, I probably can't go wrong.
Maybe the wife is right, that I was always gunna go for this & I'm just trawling to find someone who agrees with me..😂
amazeer ·
DOUBLECAB wrote:Had a T3 doublecab I bought with 12Ks on the clock and by the time I sold it at ....I think about 220Ks I had 2 lots of crankcase water seals go/fuckup at $4500 a pop.
What coolant was in it? I'm not sure why, but with T3's you have to use VW coolant which is very expensive. You ordinary wynns coolant isnt good enough. Seen a couple of t3's that had coolant additive in them but still corroded head studs and pitted the water jacket metal. Not much you can do then other than cross fingers ad hope for the best.
There's 2 types of VW coolant... blue and pink. Dont recall which one goes in what vehicle.
DOUBLECAB ·
I can only assume the first time it had vw factory coolant in because it was under warranty and being serviced by an accredited VW service centre ...when it occured the 2nd time it had Tectaloy coolant which the VW Guy that fixed it the 1st time, said should be used.......the 2nd time it was fixed at a VW centre and they said they only used Castrol coolant in all the VWs they serviced???
Hope I have a better run with the T4
Kombi_Rescue ·
guys the coolant to use now is G12+ it has a facotory rating which ia much higher than the G11 and std G12. all petrol T4 engines are interferance free when a cam belt lets go..only the diesel has the valves hitting pistons if the belt brakes .dont agree with all the thoughts regarding T3 coolant issues. firstly its not expensive to buy G12+ The T3 engine is the best flat 4 vw ever built..bar none.....all issues stem from maintance ignorance or poor fuel..........education is the key and when these babies were new only a hand full of dealers ever got the ducks guts...TKM have a lot to answer too for all VW owners incliuding the parts pricing structure.....we payed thru the nose when the factory wasn't involved...any way enough of a whinge..doublecab be sure to clean your throttle body on a semi reg basis..this is particular for engine codes AET...use a good grade fuel to avoid maniflod cracks..regular oil changes espeacially if you are a low mileage driver...every 6 months....check g/box oil level and you shall see many more thousands of k's under your belt....when u r ready try a T5 it will blow your socks off...just when you thought how much better can they get cheers steve
DOUBLECAB ·
Anybody know where I can get service books and owners manuals for T4 and what should I be paying?
Spook ·
OK, so let us say my bank loves me (should know by tomorrow), & I grab this.
Premium unleaded is the fuel, g12+ is the coolant.
What's the engine & gearbox oil??
Spook ·
Turned out to be less than I hoped for.
So as of Friday I will be the proud owner of a '90 T3.
[ Edited on 11-1-2006 by Spook ]
amazeer ·
Spook wrote:Turned out to be less than I hoped for.
So as of Friday I will be the proud owner of a '90 T3.]
What about the T4? 🙂
Spook ·
I'll clarify my last statement.
The T4 was less than I hoped for.
