Hey all,
Does anyone know how much you can narrow an Ovals front beam before you need to make body shell mods?
Cheers!
Gibbo ·
https://forums.aussieveedubbers.com/threads/47598/front-beam-narrowing
Gibbo ·
Unity-28 ·
vwtyp2 ·
Gibbo ·
hellbugged ·
Gibbo ·
Unity-28 ·
Dasdubber ·
Unity-28 ·
Hey Das, It can be done, you just need to get the measuring right....Here is one that was done on lowlifevw.comDasdubber wrote:From memory Gibbo you'll be able to go 2in and retain the shock towers (but need to have them modified so a flat plate replaces the pressed/raised inner face of the shock tower). My friend had his k/l pin front end narrowed 2in in the above way by Custom Offroad and his shock towers are pretty much hard up against the body.
If you haven't got paint yet you can "massage" the body with a BFH (big f'ken hammer) to allow a bit more room. I did this with my b/j front end and inner gaurds so I could narrow mine 80mm.
I could be wrong but I'd be surprised if you can narrow it 4in without modifiying the body, or doing away with the shock towers/modifying the shock towers - I'm happy to see evidence if people have done so without the above mods.
Alan
HGFS ·
HGFS ·
Dasdubber ·
Cheers N! - that is a cool way to do it. What I was mentioning above was it would be hard to narrow it 4inches without "doing away with/modifying the shock towers" (as done in the lowlife example - ie. modifying the shock towers).Unity-28 wrote:Hey Das, It can be done, you just need to get the measuring right....Here is one that was done on lowlifevw.com
http://www.lowlifevw.com/phpBB2/viewtopic.php?t=4866
N!
Unity-28 ·
Of for sure man, You would be hard pressed narrowing more than 1.5 inches without modifying anything on a link beam....Dasdubber wrote:Cheers N! - that is a cool way to do it. What I was mentioning above was it would be hard to narrow it 4inches without "doing away with/modifying the shock towers" (as done in the lowlife example - ie. modifying the shock towers).Unity-28 wrote:Hey Das, It can be done, you just need to get the measuring right....Here is one that was done on lowlifevw.com
N!
Keep the pics coming - good to see how others are doing the narrowing!
Brad ·
