Has anyone seen one of these setup in a bug, puse generator insted of a speedo cable and the like? I've them in Hot rods just wondering how they go?
barls ·
im thinking of one of these as im looking at bigger tires than stock. im fairly sure baja wes has a similar set up in his bug
wombatone ·
I figure it would be great for different tyre sizes, the one I'm looking also has four resetable odometers and trip meters and a built in tacho. Think it should work well but not sure how easy it will be to read on the track.
BiX ·
i have a bike one hooked up, used for nav runs but not auper acurate for distance, as it averages the speed. Great for speed though!!
If you dont mind having a non original speedo, buy a new electronic VDO speedo, they are user setable and are pretty accurate.
Just bought a new tacho/speedo for the new car. $410 us, about $610 here.
It has many features
Stepper motor driven needle for high accuracy and definition
Built in LCD display
Quartz microprocessor accuracy
Built in three stage shift light system with independently programmable shift points
Facility for external shift lights
Peak recall facility
Low battery warning
Fits any ignition system or tacho output
Suitable for 1-16 cylinder engines, 2 or 4 stroke
Switchable backlight brightness control
Available with standard Black or Classic white dial finish
RPM range 0-9000, 0-12000, 0-15000, 0-16000, 0-18000
Comes complete with comprehensive manual, sensors and wiring loom
Digital LCD for displaying engine RPM or MPH / Km/h and programmable menu settings
Standing quarter timer including terminal speed
Programmable acceleration timer e.g. 0-60 MPH
Programmable mid range timer e.g. 50-90 MPH
External sequential shift light display unit available
Digital setting of tyre size and trigger points
Switchable odometer & trip meter
[ Edited on 11-1-2006 by 1303Steve ]
VDUBXTC ·
These are a cool little item.
Contact Secoh on this forum if you are interested in one.
I like your option Steve. It's got some nice features. how does it sence speed? what type of probe and how do you plan to mount it?
It just uses a magnetic pickup, I can mount it on my front hub or on a CV at the rear.
My new car is a 1303 and I want to do something different with the dash, maybe something like this below.
When I bought my Spa Speedo/Tacho it was cheaper to buy from the US than the UK.
[ Edited on 12-1-2006 by 1303Steve ]
Baja Wes ·
I've got the MX6 dash that goes with my motor. I am currently resetting it into my dash along with the digital climate control.
Yes the instruments are digital, and use a digital pick-up, but are analouge dials.
I am also installing a Jay-car speedo correction kit so the speedo and odometer are correct. I have been using a temporary (for the last 2 years) sticker over the speedo to make it correct.
silverbullet ·
I have been looking around for a digital dash my self. Has any one heard of Dakota digital gauges?
wombatone ·
Dakota is what I'm looking at, Planing to make a copy of the early style gauge set up for oval bugs in the center of the dash, with a 80mm speedo/tacko and two 50 mm for oil temp and pressure and the other fuel and volts. They say it will take about 30 day to make and send over from the USA. Am also looking to replace the original speedo with a SPA tacko/speedo, they say they can built a custom 0-7000 rpm tacko on request.
custom off road might be able to tell you where he got them from
i cant remember
terry
silverbullet ·
Air ride in NSW are stocking these items was talking to them the other day i am looking at the slim line one Which is about 5x 40 cm think it would look pretty cool flush mounted into the dash.
