REVERSED COOLANT MANIFOLD EJ22
https://forums.aussieveedubbers.com/threads/47865/reversed-coolant-manifold-ej22
neggy17 ·
Ive seen that lots of people have reversed there coolant manifold. What benefits do you get? Is it worth doing? Ive had a look at mine on an EJ22 and there appears to be two sensors going to the manifold and a small rubber pipe. If the manifold is reversed do you just have to lengthen all of these? Also the two pipes that used to go to the heater matrix i was going to join together as i will not be havig a heater but with the manifold reversed these will be no where near each other. Is there a good way to rectify this? By the way the engine is going in a Beetle.
Cheers Neggy
rubyred ·
its alot easier to route that 1/2 inch line for the heater across the engine, than routing the 1.25 or 1.5 inch pipe completely around the engine and making a 130 degree angle to point towards the front of the car.
it also allows for a cleaner engine bay.
subaruboxer ·
Hi Neggy,
the benefit is that the coolant manifold is going in the right direction (where the radiator is located).
You don´t have to lengthen the wires for the sensors, but the hose got to be replaced by a longer one. You have to get the wires out of the harness under the intake manifold and get them where you want them.
I did that with my engine (ej 22) in my beetle.
Take a look at my post " My cooling system" on page 2 here in the forum.
Jörg
rubyred ·
here is how i did mine. I just cut off the end, and welded a bead on it. has worked perfect so far.
-Ryan
neggy17 ·
Hi Jorg, Ive just had a look atyour previous post, that looks like one neat install!!! Did you join the heater matrix pipes together? Can i also ask what you cleaned your engine with as im worried about getting water in the engine? What radiator is that that you have used?
Cheers Neggy
subaruboxer ·
Hi Neggy,
i used gasoline and a brush for cleaning the engine (to get rid of the wax), my radiator is of a rabbit (Golf) Gti but it does not fit into the spare wheel well without some cutting and extending it. The smaller radiator of a 75 HP rabbit (Golf) fits in right away. It is big enough for the subaru engine, i took a Gti model , because i started my conversion with a Gti engine. And yes, the heater pipes are connected.
Jörg
[ Edited on 12-1-2006 by subaruboxer ]
subaruboxer ·
Hi Neggy,
for a reversed coolant manifold that has the heater connection on the same side as stock take a look here:
http://www.rjes.com/home.htm
I don´t know where you are located, it is in GB. Maybe that is to far away for you.
Jörg
neggy17 ·
Thanks for the help!! I am now definitely going down this route. Ive had a look at that website Jorg and i think im going to copy the heater connection as i work in a machine shop. Ill get this bit done and then ill probably have some more questions about the other pipes on the engine.
Thanks again Neggy
