I have a prob with my clutch on a 67 beetle.
At the moment it feels like there is no clutch, like it is all freeplay. The clutch lever on the tranny is moving as the pedal is depressed, correctly I think. The freeplay adjustment wingnut was already at max tightness, so I tried sticking on a nut to give me extra tighning ability. Now when the pedal is depressed, and the clutch lever is moving a bit further there is a loud screeching.
I can't put it in gear while the engines running.
Any ideas?
pod 路
you can over adjust the clutch,and you might have popped the thrust bearing out of its holder which means an engine out job馃檨
1500S 路
Maybe one arm of the clutch fork has broken off the shaft. Not uncommon on some models as they weren't welded too well.
Edmond 路
ok, thanks for the info, looks like I have to pull the engine.
I haven't done it before, so I'll get to investigate what goes on in there.
helterskelter400 路
if you have to take the motor out, you might as well cut the back bodywork off and turn it into a baja so that any future motor tuning/adjustment/servicing and removal and stuff is like 10 seconds work...
(joke guys, joke..)
bajachris88 路
sux when u got barwork in the way though 馃憥
last celtic warrior 路
Well, I'm not joking, cut it... Make a nice Baja out of it.
But with the clutch, have you tried looking at what the components are doing with two people? You can really benifit from having a second person there to operate the clutch while you see what's actually happening, while it's happening.
ash logan 路
I am in the exact same situation with my 63. What you have described is exactly what happened to mine the other day.
The local VW mechanic had a quick look at it and he thinks the clutch fork has broken. From what 1500s and many others have said, its a reasonably common problem.
See my thread titled "$250 labour + parts for a clutch fork replacement??" for a bit more info.
I am considering repairing mine myself and i would be interested in hearing how you go and what issues you come accross.
vw54 路
Could also be the clutch hook on the pedal cluster broken or torn away
