I posted this in another thread but now its worthy of its own.
The kombi was running on and skipping a bit so I took it for a service. My normal mechanic was still on holidays so I took it to another trusted mechanic who gave it a half service but advised I get the carbi's checked/overhauled.
On the advice of the carbi shop I agreed to a $400 twin carbi overhaul.
Since then I have had problems.
Loads of stalling, lots of flooding etc
The most recent is it starts fine, autochoke comes on, I can drive it and it will idle in gear ok (its an auto) but when I tak eit for a run on the freeway it will stall when I slow down and wait at lights. It will not start for 10-15 miinutes and then its fine again
Any suggestions?
Please call if its easier and I will call you back
0438006704
Its urgent because I dont want to waste anymore money on this that dont fix the problem
azz ·
What no one has ANY ideas?
Only just woke up sorry. I sleep untill 1 on a Sunday. No kids you see 🙂
I say this quite often, and I will say it again. Check the distributor as I went down this same path on out twin carb 1800. I got the carbies done at a cost of $340 a few years ago, and not long after it was stalling before that the idle was high and low, not consistent. I was reccommended to get the carbies done by a mechanic also. They may have needed doing anyway, but they were not the main problem.
In the end it was a worn baseplate in the distrubutor. It was allowing the points to behave in an inconsistent way and when the dizzy got hot it would close up the points gap, and not start for a while.
It would be worth checking the settings on the auto chokes too.
azz ·
Thanks HellBus
Thats sounds like we have identical problems
I will let the Carbi mechanic know tomorrow about the baseplate in the distributor.
I feel like I have been ripped off fairly significantly by this guy/shop but what can I do he still has to work on the engine as it is worse now than when I took it to him...
ps I have a 1.5 year old son so I was up at 05.15 😁
azz ·
Could it be something to do with the coil?
Not very likely, but if you have another 12v Bosch coil around, even one from an old Holden, you can try it and see the difference. It is not worth buying a new one just to find out. It will only take a few minutes to get hold of one that works and swap it for a while.
I eliminated any carby, distributor or idling problems when I went Subaru engine 🙂
azz ·
Helbus wrote:I eliminated any carby, distributor or idling problems when I went Subaru engine 🙂
Yes and you eliminated any chance of remaiining 'original' too...🙂
How much is a coil and where would I find an old one that works?
Im an Intensive Care Nurse...not a mechanic
[ Edited on 15-1-2006 by azz ]
azz wrote:Yes and you eliminated any chance of remaiining 'original' too...
I could go back to original, but I choose not too. The beetle we have is 100% original except the CD player. Still has rubber mats on floor and had original 1971 windscreen up until a week ago.
Most old coils do work, They don't fail very often. It is an advantage if you can get one off another car, however if you cant, any auto parts store will have them for about $40. A standard Bosch coil is all you need, they fit most 60's and 70's cars. The parts store may have another brand, but it will still work the same.
azz ·
^^ cheers
azz ·
Carby mechanic says he has checked the electrics (distirbutor, leads, base-plate, coil etc) and he says all of it checks out.
So must be something he did with the carby overhaul.....idiot
Wont post the name of his business here yet but I am very very tempted
Yep once dizzy, coil, leads all check out, there is only really air leaks and carbys left. He may have bumped a rubber elbow on the manifold balance tube and it may have cracked or popped off. Quite common for old rubbers as they get brittle.
mnsKmobi ·
Try removing the spark plug leads one at a time with the engine running. If one cylinder is to blame removing its lead will make no difference to the idle. You then need to isolate why it's not working! My suspicion is that it is running too lean because of a vacuum leak. When the choke's on the mixture is rich enough to run ok. When it's off it's too lean to fire properly.
azz ·
mnsKmobi wrote:My suspicion is that it is running too lean because of a vacuum leak
How do we check for a vacuum leak then?
azz ·
I know when he hooks up the air lilfter to the carbs it drops its idle rate quite considerably....
Every now and again (before this debarcle) if the Kombi back fired it was common for a 'vacuum tube' thingy to be blown off. It was easy for me to diagnose because it would always start but not idle
azz ·
got it back from the carb guy today...he is bamboozled and cant fix the problem.
drove it home and it hasnt stalled yet so he may have fixed it by replacing dizzy leads
he mentioned tapets and because its an auto they may be loosened and that the stalling problem...any ideas?
mnsKmobi ·
Apart from the obvious issue of looking for any unattached hoses, the usual way to checkfor vacuum leaks is to spray WD40 or similar around the throttle shafts, the base of the carbs and where the inlet manifolds attach to the heads. If the WD40 hits the leaking spot some gets sucked in and temporarily richens the mixture increasing the engine revs a bit.
As I suggested earlier, taking off the leads one at a time can isolate which cylinder(s) is at fault.
General_Failure ·
Does it really cost that much to get the carbies overhauled? What do they do to them for that price?
I think I will go with plan B and fit a dual throat carby from something else rather than pay that to fix my ailing carbs 🙁
Well, if it's the tappets, it would take your mechanic 30min maximum to adjust them.
True enough, old Bosch coils are pretty universal. I usually end up shoving a bosch GT40 in things. Usually to help out with a badly worn electrical system. I know, naughty me.
Sounds like he badly botched the carb overhaul though. The dual carbs are tempramental to get running properly, however they are very simple too and it's hard to make a major mistake.
I had a vacuum leak once on the brake booster vacuum line. That took me a while to find.
I realise that you said that a vacuum line comes off when it backfires. It shouldn't backfire in the first place though. There's something else at work here.
koolkarmakombi ·
azz you icu nurses are all the same, ventilate and sedate!
in psych we find the problem!
buzz me, come over, bring beer and we shall fix!
kkk
azz ·
koolkarmakombi wrote:azz you icu nurses are all the same, ventilate and sedate!
kkk
wow freaky..who is this????
anyhow Irwin from Phoenix Engineering fixed it and it is running perfectly now...better than ever
he replaced the
coil, points, condensor, disi rotor and loked at the tapets
best $150 ive ever spent
kkk
he replaced the
azz ·
You psych nurses are all the same. Largactil/Respiradone etc, lots of ping pong and ciggies.
You are probably the most hedonistic, self abusive and incestuous group of nurses I know 🙂
