A Westwood wrote:Bay bus camper Kid that looks remarkabley like Custom Offroads radiator design and yes it does work well at all temperatures in the centre of the car but is still in development and i feel that a tapered design works better as it compresses the air at the back of the scoop forcing it threw the rdiator as aposed to the louvred design where the air is not condenced any where and is possibly turning circles and not going threw the radiator as much as thought, any way just my theirios as a past sheetmetal worker in the air industry. Andrew
Here are the issues I see:
1. Protect radiator
With an undercar radiator, this is just a matter of preventing bouncing stones and other road debris from coming in contact with the fragile bits of the radiator. A frame around the radiator and a suitable vented panel on the face of the radiator should be adequate. For the vented panel, I favor a stiff expanded mesh, though louvered sheet metal (like the COR setup) should also work. The only thing I have against louvered panels is that they might restrict airflow more than the expanded mesh.
2. Ensure good airflow while moving
The only solution to this is to hang a decent sized scoop into the airflow. The goal is to get enough airflow to allow cooling without resorting to the cooling fans. The scoop should also be screened to prevent entry of stones, birds, etc.
3. Prevent recirculation of cooling air
When stopped or at low speeds, the fan will eventually be called into play. If it is too easy for the air to circulate back around to the inlet side of the radiator cooling will be compromised. It's tough to keep things going the right way under the vehicle, since natural convection is working against you. I think the best solution is to simply box in the frame rails toward the front of the vehicle to provide an inlet scoop up front and guiding the air backwards and then down through the radiator mounted just forward of the rear crossmember. This puts the air outlet several feet away from the air inlet and gives fresh air a chance at getting into the inlet. Smoothness inside the duct isn't really a concern, as it just serves as a plenum chamber, hopefully pressurized a bit by ram air from the scoop at the front end of the inlet duct. The duct does need to be well-sealed, with attention to the gaps around the radiator, between the frame and the floor, etc., as the air will take the path of least resistance and we want that path to be through the radiator!
In light of these, the splittie bellypan might well provide the duct/plenum desired for a radiator setup. The bellypan wouldn't have to be as strong as the reinforcement bellypans, but the basic concept is fine. You'd still need to fashion a scoop at the front to provide some stagnation pressure for the duct.
George
[ Edited on Feb 04, 2006 by GeorgeL ]
