Aussieveedubbers 路 New Members Forum
Somethings a missing here????
https://forums.aussieveedubbers.com/threads/48359/somethings-a-missing-here
firefly 路
Hey all.
It is in great trauma I come to you as a community and a novice. If it was a holden or even a Hillman I would be at home, but my wife after seeing two beetles (Fleur's[Helbus] ew one and another friends) it seems that she has decided that the Commodore we called hers is now not any good.
Now I have been around computers a very long time and (under a different handle as oldn64 does not seem right here) am a wealth of knowledge and am a moderator for a few other forums. Having stated this I just do not get this air cooled thing????
Not to mention I feel very stupid right about now!! So in an effort to help my wife to get a good beetle I need some knowledge. So I am guessing I am really trying to say H E L P
Lets start at the top.
1. I am not sure on what the hell a semaphore is???
2. What are the usual rust places for beetles?
3. Model which The lady likes seems to be 63-67
4. What is the differences in 6v to 12v? (i am electrical engineer so do understand the elctrical side of things just more intewrested in the vw side of things...)
5. Have seen a number of beetles claming shortened front tubes etc etc why what does this mod do???
6. Have seen a number of beeltes stating a 5 speed box. where does ths come from o i it a typo?
7. do you oftenhave isues wth battery and therear set?
8. What is the difference between twin port and single port heads (it is the facility for twin carbs???) the only other thing I can think of is that the heads are like the holden six (red) and thus have the shared inlets...
9. Why do some beelte have neg camber on rear and others have positive?
10. what is the difference between the straight axles and a swing arm gearbox? why the difference?
11. What is required to place porsche rims on the vehicle I know there are two types of stud patterns but porsche are different again.
12. how do you make a beetle stop? again if EH or Hillman easy as but beetle seems foreign.
13. As you can see I am the mechanic and general worker the driver on the other hand just wants to do that Drive it. So is $4000 reasonable for a 66 model or are we getting ripped?
T (aka Oldn64) 馃榾
Let the knowledging begin!!
hellbugged 路
hang about, i'm working on it.
first of all, welcome, the prefered terminology for the "c" word is conformadore
1- rectangle indicator that sticks out from the "b" pillar- pre 60's beetles, not sure about kombis- over $100 each if your not lucky enough to have em
2-did you say the "r" word, tisk tisk.in the bonnet under the spare wheel and under the rubber seals
behind the wheel arch (front) bottom of "a" pillar where the door hinges screw on. bottom of doors inside and out. under the 1/4 vent windows
the "heater channel" ie. underneath where the doors close from front to back, look behind the running boards from underneath the car to spot this one.
in front of the rear wheel arch, the rear bumper mounts and rear apron
the lower sections of mud guards, bonnets and "boot" or "decklids" ie. rear /engine cover
floor pans halves- to the point where they dissapear altogether- flinstones style.
theres more, but hellbus knows evey single one
3--- the pre 68 beetles all have similar overall appearence, after that they changed a few times
4-- 6 volt electrical systems. sometimes refers to appearance as mentoned in point three, as the 12volt system was introduced with the change of body design. a well maintained 6v system can work fine, but dull lights, no stereo etc. you know what would be involved in changing the system over, so lets just say its easily done with no modifying, take out, bolt in replacement
5---- wild to mild, "narrowed" front ends are either for looks, to go real low, or to gain clearence on outer mudguard lip for the wheels/tyres or a combo of all the above.
6-----5 speeds can be done and involves a new section being added to the nose of the gearbox to accomodate the 5th gear. the diff is integrated into the box, so its not a matter of getting a celica box, rear engine cars eg porsche can be used, either way 5 speed equates to big $$$$$$$$$$$. the four works fine as the 4th gear was designed quite high from the factory- remeber autobahns!
7-----now your'e saying the f word! fire? it does happen but rarely, but the seat is not bolted down, so matainance is easy. acid leaking on the floor is not good, so battery clamps should be working, a simple rubber door mat will almost expell the myth of fire caused by short cuircits
8---single port heads have one hole on the ouside of the casting, and split for the two valves, within the head itself.
dual ports have two holes/ports all the way through the head, and further up towards the carbie (single barrel) the manifold splits it from 4 individual to 2 then joins to 1.
opinions of performance differences are endless
9----depends on height of suspension mainly.REAR END/AXLE lets think about a see-saw, teeter totter. just think about what goes on from the pivot point to the end you are sitting on.
when you go up, you lean forward, down you lean back.
the v.w axle pivots from the gearbox,(which makes this point almost at the centerline of the car) when the axle pushes up towards the body(lowered), the top of the tyres leans forwards towards the center line-NEGATIVE camber! opposite produces positive camber.
the camber varies a touch as the vehicle is under power or coasting, cuased by squatting/loading rear suspension
10---pre 1969 beetles used swing axles or straight axles.
after that they added a diagonal trailing arm and C.V joints to cure the camber changes associated with one piece axles. refered to as I.R.S- although they were all independent of each other
back to the see-saw.a c.v joint allows the plank of said sesaw to bend at both the middle and seat end. the one at the seat end conteracts/corrects the angle created as it goes up and down. now you dont laen back and forth, your camber doesn't change! do you fell less sensation/safer? not a bad thing for a car hey!
theres more too it, but thats the basic of it
11---5 holes/wheel bolts for early-6volt-pre68 beetles.
4 holes for later, 68 onwards
5 holes for porsche-interestingly, the same distance from the center pont of the hub as four stud V.W pattern-only 5 holes instead. this is why it is possible to redrill and use studs and nuts, or drill and tap for wheel bolts-- not recommended
new "blank" v.w rotors/drums can be bought and drillied to suit all sorts of patterns other than porsche. they are a original v.w size and as such, use the other associated original v.w parts. its just like renewing the worn out ones, just bolting on the replacement parts, only with a different pattern!
or you can use porsche set ups, including the BIG calipers, pads and rotors you would expect from porsche. more complicated due to the different bearing/stubs sizes and offset issues
12--- put your foot on the middle peddle and PUSH!
if that doesn't work, try the handbrake! some people call it the emergency brake.
turn the key to the off position.
13--- that depends. spend $10000 and be done with it!
see here:
http://forums.aussieveedubbers.com/viewtopic.php?tid=48328
:sandrine
[ Edited on 26-1-06 by dumone ]
bajachris88 路
Well, i can answer a few, i can't say i'm the pro, but heaps here are.
A semaphore is one of those 'classic' indicators that flip out from the side of the car. On the bugs, it flips out from a position like in between the driver door and rear window. Have alook at these pics of it:
http://www.bugology.com/cgi-bin/gi_v1.cgi?a=4&b=1 (see the rectangle heading downways on the side of the bug, to the left of the rear window? Thats the semaphore, without being retracted out.
heres what it is, retracted out (when u go to indicate): http://www.bugology.com/gallery1/semaphore1.jpg
I don't think they make em for any 1960+ dubs though. But no 66 will ave em. Well, not stock anyways, spose someone could mod em in.
bajachris88 路
usual rust places? Lol, well, i'm learning that myself.
from what i have seen, mainly, is along the heater channels (helps if u get a bug with the least amount of rust in the channels, cause they can be a challenge to replace. if u replace and reweld em in and don't do it spot on, the body will be crooked (as i have heard), cause they are the main strengthening for hte body.
um, the A pillars a big rust spots too (got taht myself). the floor can be nasty sometimes too the flooring can be pretty rusty, and sometimes there are situations where ur feet can fal through.
Um, under the hood, in the spare tire well, can get rust there, water sometimes gets trapped. i got a bit of rust down the bottom of my doors too. A little bit too around the edges of my windows.
when it comes to 6 and 12 volt kinda things, am going through that myself. But.... i'm not sure what it goes with yr models and which are 6 and which are 12. I go the later are obviously the 12vs, ur 66, well it could be 6 volt if its still original. my 67' is 6v.
It just means that ur light bulbs, battery, starter, alternator/generator, coil, wiper motors, water pumps etc, Everything electrical is build for 6volt source.
[ Edited on 26/1/2006 by bajachris88 ]
firefly 路
Ok, number of things.
aver spoken to previous owner. Car seems honest (if you know what I mean) has been sprayed recently (a Rav4 colour) and had mostr of the rust cut out. The car has been serviced by a Bug mechanic and seems to be pretty good. The car has been lowered all around and has been converted to 12V (properly done, well as much as a auto elec can do anyway.
From the rust department there is some in the front apparently under the guards (I would suggest inner guard not outter. As I have not seen the car in the flesh I cannot tell you much more than this. The running gear has only done about 17000 miles since rebuild. So all seems good thus far.
Are the inner guard normal rusting locations? It runs a 1600 and single carb. the beetle exhuast and silencers have been readded after the owner got sick of the drone. All in all it seems a good base to start with but will know more tomorrow... any pointers. Just to give peoples an idea here is a photo of said car from owner after discussion.
T
firefly 路
Ok hang on a few more thing I forgot. Firstly thanks for the heads up guys (non gender specific.. 馃槈)
dumone wrote:1- rectangle indicator that sticks out from the "b" pillar- pre 60's beetles, not sure about kombis- over $100 each if your not lucky enough to have em
Coolo sounds like the morris idea. would be 50's vintage. thus should not be on a 60's car unless modified beyond belief. Not a huge issue just saw it plastered everywhere but no one really told anyone what they where. maybe a VW encyclopaedia my be a good idea for newbies. 馃槈
dumone wrote:2-did you say the "r" word, tisk tisk.in the bonnet under the spare wheel and under the rubber seals
Yes yes, I believe the front wheel arch might be the one which she speaks of but again will nto be 100% sure until I look closely with this. Might need to speak to Pete tomorrow. I have his number somewhere here. Actually Pete (or anyone really) if it is wheel arch drivers and passeneger will a type 3 wheel arch match a early girls body??? If thw wheel arches are rusted would you expect the rest of the "normal spots to have gone or started??? ie does this rust lead to the establishment of other areas as per above??? Unfortunately I am a realist and the onyl cars that dont rust are aluminum, and even then they usually have steel chassis... :S
dumone wrote:3--- the pre 68 beetles all have similar overall appearence, after that they changed a few times
My lady seems to like the smaller numberplate light and teh longer nose, if you know what I mean...
dumone wrote:4-- 6 volt electrical systems. sometimes refers to appearance as mentoned in point three, as the 12volt system was introduced with the change of body design. a well maintained 6v system can work fine, but dull lights, no stereo etc. you know what would be involved in changing the system over, so lets just say its easily done with no modifying, take out, bolt in replacement
Was more after the general costing of parts but seeing the one we are looking at first is already 12v I might not need to travel this road.
dumone wrote:5---- wild to mild, "narrowed" front ends are either for looks, to go real low, or to gain clearence on outer mudguard lip for the wheels/tyres or a combo of all the above.
Considering the above piccy you think it has been narrowed. I asked this question and was told they did not know anything about that and that the car was bought this way having never been touched by current owner. the other thing is that the car has been to the mechanic (some beetle place) which had not commented at all about this.
dumone wrote:6-----5 speeds can be done and involves a new section being added to the nose of the gearbox to accomodate the 5th gear. the diff is integrated into the box, so its not a matter of getting a celica box, rear engine cars eg porsche can be used, either way 5 speed equates to big $$$$$$$$$$$. the four works fine as the 4th gear was designed quite high from the factory- remeber autobahns!
Point taken thought the aussie cars got different box to that of GmHB... Guess will take a look at the whole picture and see how one drives first... Was a very very long time since I last drove a beetle (try 10 years ) and it was only for 30 minutes. Cannot remember too much of the "experience" at all.
dumone wrote:7-----now your'e saying the f word! fire? it does happen but rarely, but the seat is not bolted down, so matainance is easy. acid leaking on the floor is not good, so battery clamps should be working, a simple rubber door mat will almost expell the myth of fire caused by short cuircits
Sorry realist again, just not sure too much of the implecations of internal battery... not hugely keen on the idea so a gel pack might endup there instead. 馃槈
dumone wrote:8---single port heads have one hole on the ouside of the casting, and split for the two valves, within the head itself.
Think I might need more information on that one. Not wanting car to be slow for her, but am wanting it to drive with the traffic. (ie freeway speeds for merging and general traffic flow. Understand it is not a new car but my Gazelle (hillman) stays with the traffic no issues, a beetle should too.. 馃槈 then again the gazelle did come with 110HP from factory.(woohoo Cortina GT beater.. :P)
dumone wrote:9----depends on height of suspension mainly.REAR END/AXLE lets think about a see-saw, teeter totter. just think about what goes on from the pivot point to the end you are sitting on.
This one does not look too bad at all, not sure whether that is worrying or not.. :S
dumone wrote:10---pre 1969 beetles used swing axles or straight axles.
Think I got the general idea. from what you seeming to describe you are saying that this might suffer from axle tramp a huge amount (nad before people start telling me that axle tramp does not exist in a IRS setup car, I will take anyone for a ride in my VR SS and show you... eek, nice ride but give me a Live rear anyday.
dumone wrote:11---5 holes/wheel bolts for early-6volt-pre68 beetles.
again reason for asking was it help the thing stop. why reinvent the wheel (excuss punn) when the company has already done the reasearch?? I want the thing to stop.
dumone wrote:12--- put your foot on the middle peddle and PUSH!
Um yer... :S I know how to drive more from a car stopping ability, from memory it was not the greatest in the stopping department, so was more trying to guage what is required to pull them up better...?
dumone wrote:13--- that depends. spend $10000 and be done with it!
see here:
Um well out of her price range.. 馃檨 it is very nice however!!
The other stupid question... where is reverse in the shift pattern? the other thing is what I do remember of the shift pattern you sort of just point the shifter in the "general" direction of the gear you wish and it sort of finds it.. :S (slop city style.. 馃檨) Can this be fixed, or where they like this from factory... ie how does the shiofter work??
T
PS: sorry for the ignorance. Knowledge sadly lacking here.
firefly 路
How come the BBcode seeming not to work for me??? grrr
T
blutopless2 路
firefly wrote:The other stupid question... where is reverse in the shift pattern? the other thing is what I do remember of the shift pattern you sort of just point the shifter in the "general" direction of the gear you wish and it sort of finds it.. :S (slop city style.. 馃檨) Can this be fixed, or where they like this from factory... ie how does the shiofter work??
T
firstly welcome aboard.... better to ask lots of questions (even if you think they are stoopid) than regret it later!
with regard to the shifter... it shouldnt just drift around and have plenty of slop... that could indicate the shift coupling is worn and will soon fail (no biggy to replace... can do it yourself)
reverse is - from neutral push down... then far left... then towards rear of car (in direction of second gear)
good luck with the beetle.
helbus 路
Hey Tim, it seems ya missus liked Fleur's beetle when she saw it 馃檪
Oasis 路
You could get a Berg or Empi short shifter which makes the gears very direct with very short throws too: like this... http://www.geneberg.com/product_info.php?cPath=17_475_2971&products_id=1174
Fantastic to use but get one with the button on the right (for your left hand thumb) looking from above...
A 1200 is slow 路
firefly 路
Helbus wrote:Hey Tim, it seems ya missus liked Fleur's beetle when she saw it 馃檪
Gee you sure??? :P
OK to add to what has already been, we went and saw a beetle today which had a price tag of $4000. on close inspection there seemed to be a number os "issues" Some of which are not normal other which are beetle. (if you know what I mean)
this particular example whilest not as bad on looking at issues as Helbus's originasl blue/purple beetle would require quite some work and In discussion with helbus believed we might find a better example out there for our said moneys. There is however a few more questions that arrose from this.
1. Workshop manuals can you get them and are they something other than the good old gregories/haymes publications???
2. Is it normal for the clutch to take up off the floor (ie 2mm from floor it becomes enaged...)
3. when "quick shifting" (IE clutch on floor engine rvs still comming down to idle) that the change from 2nd to third crunches occasionally. if shifting moderately works fine
4. when placed n 4th houldthe shifter drift over to the 2nd gear position (if you understand watI mean)
5. What are the normal type oil leaks we should be expecting to plug. Believe me when I say That no motor of mine leaks oil for long...(trust me the hillmans are worse than anythign else so a beetle should be a walk in the park to seal.
Do they usually only come with seat belts for the front (63-68 vintage..?)
Anyway enough for now.. 馃槈
T
helbus 路
Front seat belts is normal. Our 70 has front only.
Haymes is a good manual. John Muirs idiots guide is great for a lighter look at servicing the VW without as many technical pages. It is a much easier read for non technically minded people.
Clutch cable may need adjusting, stretched, frayed, or the clutch is worn. Adjusting the cable is able to be done without any tools. Just turn the wingnut. (Kombi anyway)
Oil leaks, well if it is pushrod or oil cooler seals, then it is a fair bit of dissassemly to put the relativley inexpensive parts in. If it is a rear main seal, again it is labour to seperate engine and gearbox and get the flywheel off and put the seal in. The easy leaks are rocker cover and oil strainer (drain plug/plate) leaks.
The concerning oil leaks are case leaks where the case halves are no longer married up and sealed, or behind no. 3 cylinder behind the flywheel is cracked. The case has to be welded or replaced.
Sloppy gear shift is normal, and new bushes or a new coupling back near the gearbox that again are not expensive will help that along. Quick shifting an original older gearbox will not produce satisfactory results as the design and wear associated will not tolerated that kind of shift all of the time. A gentle slip into the next gear should be fine, iff not, the synchros need work.
