Aussieveedubbers 路 Tech Talk
whats on the right hand side of e beetle engine bay?
https://forums.aussieveedubbers.com/threads/48609/whats-on-the-right-hand-side-of-e-beetle-engine-bay
killakornkobb 路
oil filler looking thengy?
got red hot on the drive home today.. made my firewall smoulder... not a good look outta the decklid馃檨
pod 路
the one that goes out through to under the guard is for auto trans fluid in the auto stick,
killakornkobb 路
nice one.. i really should have know that :|
wonder why it was bout to explode?
ctefeh 路
Damien,
On your A/S if the ATF temp gets to 125 C in 2nd or 140 C in Hi (maybe the other way around...) your ATF light in your speedo should have been on.
Couple of cheap checks.....
Is the ATF/Oil pump scorching hot?
Is the steel pipe from the tank to the ATF pump riding on part of your exhaust?
Is the converter scorching hot? There's two openings you can poke a finger through to check..
Gearbox excessively hot?
Ctefeh
bajachris88 路
Lol, put ur finger in, tocheck if its scorchin hot? Lol
be careful not to scorch ur fingers hehe.
killakornkobb 路
atf light didnt come on.. but a light on the left hand side of the speedo did.. looks like high beam symbol, but smaller?
could it be miswired with the atf light?
ctefeh 路
Damien,
Not having seen a 68 speedo, but I have a 70, and 71 and the ATF light is between 80 and 90 MPH. In fact it has "ATF" next to it. According to one of my manuals (covers 68/69 stickshifts) the wire to the light should be blue with red bands......check where the wire goes...If indeed it is your ATF temp warning.....you have a problem. I'm assuming you weren't driving along for kilometres in Range 1....
If your ATF pump seems OK, you could (cheap first!!) disconnect your hoses (if you do the steel feed line you'll have to drain the oil tank) and blow them out to see if there is a blockage (watch where you point those hoses!). While your hoses are disconnected, take the temp senders out and see if there is any garbage on the ends and in their respective bellhousing holes.
If I can think of any other cheap driveway checks I'll post 'em.
Ahh...just remembered...is your weber properly tuned yet?? You may be running your motor hot and the S/A parts are copping residual heat...just a thought....
Ctefeh
[ Edited on 4/2/2006 by ctefeh ]
[ Edited on 5/2/2006 by ctefeh ]
