hi guys
due to a spade of bad runs with mechanics, i have decided to do a few things myself...on the learing curve ive found the vw bus engine a bitch to work on (compared to a bug), if anyone could please help me on the following that would be great
firstly i am trying to remove my distributer to replace the points, i have followed my idiots guide and service manuals that say to only remove the nut to the engine, not the clamp nut.....i have done this yet the distributer wont move??
any advice on this would be appreciated as the points are pretty much impossible for me to do without removing the distributer.
also being the first time ive changes plugs ona bus, i droped the friggen plug whislt trying to get it out (back right cylinder whislt looking at engine), so its now sitting in under the metal sheathing on the heads....i pressume i need a magnet to get this guy out? or does the metal sheath actual only cover the top and i could push the plug over and it will drop out the bottom of the engine?
adam
The distributor should come out once the nut holding the clamp to the case is removed. It makes sense to remove it this way if you want to maintain the timing position. Will the complete distributor turn now? They have a rubber O ring that can hold it in a bit.
The other option is to remove the points with the distributor in the motor.
The plug you have dropped will need to be removed with a magnet or tongs of some kind.
adnesiac ·
cool thanks peter
so i guess ill have to wait until next weekend and look for a magnet during the week, i need to magnetise my spark plug socket too.....i tried pointy nose pliers but the hole in the casing is too small. feel like a dentist with the mirror and all 🙂
what do you mean by will the complete distributer turn now?? i havent removed it yet but i want to do it this way so if i ever need to replace it down the line, i know how its done....plus yeh to keep the timing position.....its a bit of a shit having to wait a week to change plugs and points, but its a good learning experience and build up a decent tool kit on the way!
76camper ·
As helbus said the distributors have a rubber O ring (oil seal) Once you remove the 13mm nut near the crankcase vent then just give it a bit of a wiggle while pulling it up and it will pop out! Its that simple, when u reinstall it just put the shaft in the hole and push down lightly and spin the rotor till you feel it click in. The type 4's arent that hard to work on once you get to know them... keep at it. Hope this helps
adnesiac ·
thanks 76, it all helps!!
does that mean that i have to move the rotor to get the dirstubuter out??
Chewy ·
No, just wiggle it by the body and pull up, if that doesnt work, loosen the clamp and try.
put a bit of grease on the shaft/O ring next when you re-install it.
76camper ·
no need to take off rotor, just take cap off and leave it in the car so u dont forget which wires go where.
I prefer to remove the 13mm nut and remove the clamp as well, that way you dont bugger the O ring, the timming will still be right within a few degrees.
kombibob ·
???? there is no reason to remove the dissy to replace the points.
type3lover ·
It's easier to change / set the points in a kombi with the dizzy out I reckon. Only takes a minute to remove it so why not?
It may be corroded in place and therefore stuck in position in the crankcase. I had this problem in a Volvo once. Took lots of wd40 and persuasion to loosen the dizzy!
If you can't turn the dizzy body with the clamp loosened then this could be the prob.
Cheers!
Toby
vwking ·
the best way i have found to remove spark plugs is to loosen them with a socket then slide a peice of garden hose over the end of the plug then just screw them out put them back in the same way:thumb
geodon ·
Thank you vwking!
I've been pulling plugs out of dark crevices for 4 decades & that's the best idea I've come accross! There is only so much torque u can apply with ur fingertips on a thin threaded plug end! It should minimise the cross-threading problem too.
[ Edited on 15-2-2006 by geodon ]
76camper ·
better still, glue a peice of garden hose (or similar) to the inside of ur spark plug tube spanner thing (??). Never loose another spark plug again...
A proper spark plug socket should have rubber inside it to grip the plug
