Does anyone own a 356? I need some help
https://forums.aussieveedubbers.com/threads/4887/does-anyone-own-a-356-i-need-some-help
karmannghia60 ·
I need some help on pedal assembly and all the conducts in the tunnel
Thanks in advance
Raf
matara ·
Raf,
I've got an A, but I suppose the pedal cluster is the same. Whats the problem?
karmannghia60 ·
See pics below. The way the clutch cable & accelerator cable shafts stick out of the left side of the tunnel doesn't make sense to me. Are they both supposed to be outside the tunnel? How would the two cables go through the tunnel through the small hole? What am I doing wrong?
Raf
matara ·
Raf,
I only have these photos handy now. I will have a look later tonight and take a pic of the passenger side of the tunnel.
matara ·
Another
karmannghia60 ·
Thanks, a pic of the left side of the tunnel would be great
Raf
matara ·
Raf Here are some links to some high res pics of the passenger side.
I also took a very amateur vid of the linkage action.
My accelerator rod has a hump in it where it goes over the handbrake cable tube!
Pedal Pic 1
Pedal Pic 2
Pedal Pic 2
And the video:-
Pedal action video
Sorry if they are a bit dark, the car is garaged and under a cover.
I hope this helps
[Edited on 2-4-2003 by matara]
karmannghia60 ·
Thats fanatastic, thank you very much
Raf
