prefer in sydney area must be in good working order
darren
penrith 0425 269 516
71superbug ·
not in sydney..am in perth..but have a red L bug box....sourced it through neil(seagull) and havent put it in car yet so he should know the condition of it....was told it was in great running order.
Anthony
[ Edited on 13-2-2006 by 71superbug ]
t2 ·
might try alittle more local at this stage but if i get desperate what would the cost be to get it to sydney
darren
hellbugged ·
100kg set me back close to $400.
g-box ain't that heavy tho
66NIK ·
Good to see you taking the plunge with the irs. Just make sure it isn't lower than mine.
Nik
t2 ·
will fit the front end aswell , just trying to decide on the best way ,keep link pin or machine up some ball joint arms and use the discs on the 68 front end in the bus allready??????? delemas delemas
66NIK ·
can you open up the bushes in the beam to take the BJ arms?
71superbug ·
gearbox can be lifted by one person without too much hassle..will weigh it up and ask them anyway...always good to know.
will post tomorrow how much it would cost to send.
Anthony
Caroneten ·
I have a box up here in qld that could freght.
Brendon
tassupervee ·
Speaking of Lbug 'boxes
Neone got an 3.88 Lbug diff/pinion laying around?
I need one for a future project
L8tr
E
gearbox weight 41kg.
Fred Bloggs ·
Go for type 3 they are a bit stronger.
Fred
FRIDAY_BIG_SHOP ·
HAY NIK , IS THE PMG AS LOW AS MY 58 !!!!!
ragged ·
Pardon my ignorance, but what makes a type 3 gearbox a bit stronger?
Cheers Dave
66NIK ·
FRIDAY_BIG_SHOP wrote:HAY NIK , IS THE PMG AS LOW AS MY 58 !!!!!
Makes the 58 look like a 4x4.
greedy51 ·
i have one u can have supposta be good but i would have it hecked first 4 free come and get it
t2 ·
u2u sent greedy
greedy51 ·
u2u 2 u 2 t2 ha ha love it
Menangler ·
ragged wrote:Pardon my ignorance, but what makes a type 3 gearbox a bit stronger?
Cheers Dave
Type 3 gear boxes are the same strength wise as a Beetle box, although the Type 3 single side plate gearboxes have a 4.125 ring and pinion, 'L' bug have a 3.88, they are no stronger.
t2 ·
does that mean it has a higher top speed with less revs if i went for a t3 box?
Menangler ·
No, the gear box with the 3.88 R&P has a lower top gear to make up for the higher R&P, so it is about the same, 1st 2nd and 3rd are a bit taller, as they are the same ratios as the 4.125 R&P gearbox.
Hope that makes sence!
t2 ·
sort of makes sense , well doesnt matter anyway , thanks greedy a free L bug box :beer
