Aussieveedubbers 路 Buying, Selling & Swapping Parts
WTD Inlet Manifold 1974 LBUG 1600
https://forums.aussieveedubbers.com/threads/48939/wtd-inlet-manifold-1974-lbug-1600
Kever 路
Looking for an Inlet Manifold to suit my 1974 L Bug 1600cc.
Has the single preheater pickup. Has a small vacuum outlet to the left leading to the Air Cleaner.
If you have one that is not blocked or rusted out .. and for a reasonable cost 馃檪 please let me know.
Many Thanks
Robert
Melbourne
killakornkobb 路
single or twin port? i think i have what your after, in melb also
Kever 路
Hi Damien,
Thanks for the reply,
My Bug is a Twin Port.
Regards
Robert
killakornkobb 路
i got the manifolds to suite a 1600 twin port, all good except one heat riser is rusted out. also got the carb i was running on the manifolds too
killakornkobb 路
my bad - i had a look outside, it seems when i had my manifolds changed to fit my weber, my mate ground thru the heat risers.. and theyre not seperate pieces like on the manifold for the weber馃檨
sorry pal, thought i had what u were after
Kever 路
Thanks for looking Damien 馃檪
Robert
beerdoc 路
Let me check the garage
Give me a couple of days
Kever 路
Thanks DOC 馃檪
Are there any other possibilities should DOC not have one?
Robert
beerdoc 路
Have failed you but have not exhausted all avenues
If you still needing I will keep looking
Craig Torrens 路
I have one but I am located in Sydney.
