I picked up a neat chrome trigger shifter (empi?) from a kombi at a local wrecker... I replaced the standard shifter in my 74 bay but cannot select reverse???
Anybody got any hints or experience with these shifters?
Desert Bug ·
G'day marvin,
Is the trigger lifting the locking bar at the bottom? Might be that the wire is stretched or broken. I used a section of accelerator cable (single strand) to replace mine and has been going strong in a daily driver for 5 years since.
Cheers, Ian.
Midlife crisis ·
The trigger on my Empi short shift was not working so I undid the nut under the plate and screwed the trigger " T " handle down until it locked up on the shaft it's been working great ever since.
Marc
Desert Bug ·
Marvin,
When you've got the shifter in your hand, can you pull the trigger and move it into reverse position?, is then I can't see any reason why it doesn't work, might just be trial ond error adjusting.
Cheers, Ian.
