wtd type 34 disc brake conversion
https://forums.aussieveedubbers.com/threads/49035/wtd-type-34-disc-brake-conversion
Michael Evans ·
Wanted - a type 3 disc brake conversion kit suitable for a 1965 type 34 ghia.
Any help or ideas appreciated
Mike
Get a later model Type 3 disc and stub axle set up and bolt it onto the existing trailing arms.
The only problem you will have is that you have 4 stud instead on 5 but you can fit an adaptor plate to get back to 5 stud.
Calcool ·
Just to add to Daves comments, you can swap the back drums from a 68 or later Type 3 to your car so you have 4 stud all round.
The other important thing to finish the job is to install a 68 or later Type 3 dual circuit master cylinder and associated hoses, you will then also need to fit a new reservoir for the brake fluid.
Then you can have the best braking system.
Gotta love Type 3's.
Calcool
yeah as per above
fit the rear hubs and drums and a dual circuit cylinder as well all good news
Michael Evans ·
Thanks for the info Calcool and vw54.
Ok then, anyone got Type 3 disc and stub axle set ups and 68 or later Type 3 dual circuit master cylinders and associated hoses they want to sell.
Mike
GTMac ·
Michael,
U2U sent.
Cheers, Andrew
